Hello Radim,
Could you (or someone else who knows this) give a more thorough explanation of what the 'rmsa' option of v.clean does (ideally in some graphical form) ?
The man page says "remove small angles between lines at nodes", but I don't really understand what this means and the French translators of the manuals are trying to understand...
Thanks !
Moritz
On 4/27/06, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Hello Radim,
graphical form) ?
If angle between 2 lines is smaller than threshold the lines
are broken and the partialy merged.
Radim
Thanks !
Moritz
Hello Radim,
graphical form) ?
Thanks for the explanation.
So if I understand correctly it does what is shown here:
http://geog-pc40.ulb.ac.be/grass/rmsa.pdf
i.e. converting the black line with a small angle into the new red line.
However, when I try to apply this to this line:
http://geog-pc40.ulb.ac.be/grass/rmsa_example.jpg
defined as follows in v.build:
> v.build brol
Building topology ...
3 primitives registered
Building areas: 100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids: 100%
Topology was built.
Number of nodes : 4
Number of primitives: 3
Number of points : 0
Number of lines : 3
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
in the following projection:
> g.proj -p
-PROJ_INFO-------------------------------------------------
name : Lambert Conformal Conic
proj : lcc
datum : bel72
a : 6378388
es : 0.0067226700
lat_1 : 49.83333333333334
lat_2 : 51.16666666666666
lat_0 : 90
lon_0 : 4.356939722222222
x_0 : 150000.01256
y_0 : 5400088.4378
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : metre
units : metres
meters : 1
Then whatever the threshhold value I set (going up to ridiculous values, I continue to get 4 nodes, with 3 lines which look identical to the original.
Am I still wrong in my understanding of rmsa, or is it something else ?
Moritz
On 4/28/06, Moritz Lennert <mlennert@club.worldonline.be> wrote:
>>Hello Radim,
>>graphical form) ?
No, this can be don with 'prune' but tolerance is distance.
I have attached picture of what rmsa does.
Radim
> v.build brol
0 areas built
0 isles built
Attaching islands:
Topology was built.
Number of nodes : 4
Number of lines : 3
Number of areas : 0
Number of isles : 0
> g.proj -p
proj : lcc
datum : bel72
a : 6378388
es : 0.0067226700
lat_0 : 90
x_0 : 150000.01256
y_0 : 5400088.4378
no_defs : defined
unit : metre
units : metres
meters : 1
original.
Moritz
(attachments)
I have added the figure into the module's documentation.
Hello Radim,
graphical form) ?
Thanks, that makes it much clearer. However, one more thing. In the source code you write:
"It may happen that even if the angle between 2 boundaries at node is very small, the calculated angle is 0 because of representation error."
And when one tries to set a threshold, the module says "WARNING: Threshold for tool 1 may not be > 0, set to 0".
So, does this mean that this tool only works automatically for those nodes where the calculation ends up with an angle of 0 ? The user cannot change this threshold.
Should the description of the tool thus read something like this:
rmsa: remove small angles between lines at nodes (Only concerns angles which are so small that the calculated angle is 0. The user cannot change this threshold.)
Moritz
Radim
> v.build brol
0 areas built
0 isles built
Attaching islands:
Topology was built.
Number of nodes : 4
Number of lines : 3
Number of areas : 0
Number of isles : 0
> g.proj -p
proj : lcc
datum : bel72
a : 6378388
es : 0.0067226700
lat_0 : 90
x_0 : 150000.01256
y_0 : 5400088.4378
no_defs : defined
unit : metre
units : metres
meters : 1
original.
Moritz
Yes.
Radim
Moritz
> Radim
>> > v.build brol
>>0 areas built
>>0 isles built
>>Attaching islands:
>>Topology was built.
>>Number of nodes : 4
>>Number of lines : 3
>>Number of areas : 0
>>Number of isles : 0
>> > g.proj -p
>>proj : lcc
>>datum : bel72
>>a : 6378388
>>es : 0.0067226700
>>lat_0 : 90
>>x_0 : 150000.01256
>>y_0 : 5400088.4378
>>no_defs : defined
>>unit : metre
>>units : metres
>>meters : 1
>>original.
>>Moritz
