On Sat, Nov 17, 2001 at 04:29:23PM +0100, Radim Blazek wrote:
Markus Neteler wrote:
> Hi,
> I think I have fixed the "NOTE: 1 new node needed" bug in v.digit.
> The problem was that the number of points needed for snapped lines
> was not reduced in
> libes/vect32/diglib/check_node.c
> (fixed). Radim, can you update for the grass51/ library?Are you sure?
/* see if this line has 2 points that snap */
if ( (fabs(xarray[0] - xarray[n_points-1]) <= map->snap_thresh) &&
(fabs(yarray[0] - yarray[n_points-1]) <= map->snap_thresh) )
node->N2 = node->N1;
new_nodes--; /* reduce as we are snapping MN */
}I think that original version was correct:
Ends of line are close together (< thresh0 and only one new node is needed =>
no need to increase number of new nodes (new_nodes). But we cannot decrease.Is it : "NOTE: 1 new node needed" realy bug? it only reports that new nodes
were added to nodes structure - are there other problems?
Radim,
thanks for your comment. You are right, I have reverted the change in
src/libes/vect32/diglib/check_node.c
and fixed again
src/mapdev/v.digit/digitize.c
Also I improved (hopefully) the messages for lines and areas.
If possible, test again.
Hope to have caught all problems now related to the "NOTE:..." messages.
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Project on Predictive Models for the Environment
Via Sommarive, 18 - 38050 Povo (Trento), Italia
tel +39 0461 314 -520 (fax -591) http://mpa.itc.it
