Hi developers,
a small problem was reported with v.digit:
If you hit "Q" to quit the module, the message
"Leave digit [n]"
does not appear on some systems.
I think it is a bug with curses_yes_no_default:
src/mapdev/v.digit
menus.c: if (curses_yes_no_default (2, "Leave digit? ", 0))
similar to the stdout/fflush thing. However, I am not sure
how to force such a fflush there.
The curses_yes_no_default() is written in dig_curses.c using Write_info()
also there.
Thanks for any help,
subject 'unsubscribe grass5'
"Leave digit [n]"
src/mapdev/v.digit
also there.
I don't think that this is an fflush issue.
Write_info() calls _Write_info() followed by wrefresh(INFO_WIN). If
wrefresh() doesn't result in the text being displayed, then it appears
that curses is broken.
In any case, the call to Write_info() in curses_yes_no_default() is
immediately followed by a call to Get_curses_text(), which in turn
calls wgetch(). Reading from any stream which is associated with a
terminal is supposed to flush any output streams. If this doesn't
happen, then the C library is broken.
> "Leave digit [n]"
> src/mapdev/v.digit
> also there.
Hi Glynn,
thanks for your notes. It seems that the fellow had a local
problem (so that's matching with above), I just received another
mail that he has it running now. Another person reported that
the problem occurs occasionally, maybe a local problem as well.
Good luck for us
----- Original Message -----
To: <grass5@geog.uni-hannover.de>
Sent: Wednesday, April 04, 2001 6:21 AM
Subject: Re: [GRASS5] v.digit menu entry print problem
> "Leave digit [n]"
> src/mapdev/v.digit
Write_info()
> also there.
to:
From: "Markus Neteler" <neteler@geog.uni-hannover.de>
Sent: Wednesday, April 04, 2001 10:29 AM
> > "Leave digit [n]"
> > src/mapdev/v.digit
Write_info()
> > also there.
Hi Glynn,
Good luck for us
to:
