[GRASS5] v.digit still segfaults
I just did a fresh cvs checkout and rebuilt grass from scratch. v.digit still segfaults :frowning:
--Wolf
<:3 )---- Wolf Bergenheim ----( 8:>
How did you run v.digit? From the GIS Manager, from the command line, both?
Michael
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Wed, 3 May 2006 19:07:02 +0300 (EEST)
To: GRASS developers <grass5@grass.itc.it>
Subject: [GRASS5] v.digit still segfaults
--Wolf
Hallo,
confirm, v.digit segfaults:
GRASS 6.1.cvs:~ > v.digit -n pokus2
New empty map created.
Neoprávněný přístup do paměti (SIGSEGV)
GRASS 6.1.cvs:~ >
(gdb) run
Starting program: /usr/local/grass-6.1.cvs/bin/v.digit -n pokus3
[Thread debugging using libthread_db enabled]
[New Thread -1240200992 (LWP 6824)]
warning: Lowest section in /usr/lib/libicudata.so.34 is .hash at
00000094
[New Thread -1240421456 (LWP 6828)]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1240200992 (LWP 6824)]
0xb776a203 in strlen () from /lib/tls/libc.so.6
(gdb)
GRASS 6.1.cvs:~ > v.digit -n pokus4
D1/5: Map opened
D2/5: cat_init()
D2/5: symb_line_init()
D2/5: symb_node_init()
D5/5: driver_open()
D5/5: -> opened
D2/5: top = 0 bot = 480, left = 0 right = 640
D2/5: n = 0.000000 s = 480.000000, w = 0.000000 e = 639.000000
D2/5: n = 4927970.730460 s = 4915893.960560, w = 593020.769477 e =
609097.969406
D2/5: Scale = 25.159937
D5/5: driver_close()
D5/5: -> closed
D5/5: driver_open()
D5/5: -> opened
609097.969406
D2/5: display_bg()
D5/5: -> closed
D5/5: driver_open()
D5/5: -> opened
609097.969406
D2/5: display_map()
D2/5: set color to symb 2: 255 255 0
D2/5: set color to symb 13: 0 153 0
D2/5: set color to symb 12: 255 0 0
D5/5: -> closed
Segmentation fault
GRASS 6.1.cvs:~ >
I hope, this helps.
Jachym
Michael
phone: 480-965-6213
fax: 480-965-7671
> From: Wolf Bergenheim <wolf+grass@bergenheim.net>
> Hi,
> --Wolf
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky@gdf-hannover.de
URL: http://gdf-hannover.de
Tel.: +49 511-39088507
Both, I even tried it with the old d.m, but the most I got was either x0 (or x1) display opened or then a tcl prompt for v.digit parameters.
--Wolf
Michael
phone: 480-965-6213
fax: 480-965-7671
--Wolf
grass5 mailing list
grass5@grass.itc.it
Jachim,
Thanks for the details. That may help someone, but doesn't help me. I just
need to know if v.digit is breaking only when opened in gis.m, whether it
doesn't work when run from the v.digit module gui, and/or whether it doesn't
work when run completely from the command line.
If it's the last, it is a problem in the C module that still needs to be
fixed; if the first, it's a GIS Manager problem; if the second, its a
problem with the module GUI.
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Wed, 3 May 2006 22:10:11 +0200
To: Michael Barton <michael.barton@asu.edu>
Cc: Wolf Bergenheim <wolf+grass@bergenheim.net>, GRASS developers
Subject: Re: [GRASS5] v.digit still segfaults
Hallo,
Neoprávnìný pøístup do pamìti (SIGSEGV)
GRASS 6.1.cvs:~ >
(gdb) run
00000094
(gdb)
D1/5: Map opened
D2/5: cat_init()
D5/5: driver_open()
D5/5: -> opened
609097.969406
D5/5: -> closed
D5/5: driver_open()
D5/5: -> opened
609097.969406
D2/5: display_bg()
D5/5: -> closed
D5/5: driver_open()
D5/5: -> opened
609097.969406
D2/5: display_map()
D5/5: -> closed
Segmentation fault
GRASS 6.1.cvs:~ >
I hope, this helps.
Jachym
Michael
phone: 480-965-6213
fax: 480-965-7671
--Wolf
grass5 mailing list
grass5@grass.itc.it
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
Did you do the following:
open a display manually (d.mon start=x0)
run v.digit
The reason I ask is that there was a problem that I fixed today that
involved automatically opening an x11 display for v.digit when the digitize
button in gis.m is pushed. But this does NOT fix any problem in v.digit
itself.
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Thu, 4 May 2006 00:09:49 +0300 (EEST)
--Wolf
Michael
phone: 480-965-6213
fax: 480-965-7671
--Wolf
grass5 mailing list
grass5@grass.itc.it
Yes, and all it does is open a new monitor.
I also get the following error:
child process exited abnormally
     while executing
"exec -- d.mon start=x1 >& /dev/null"
     ("eval" body line 1)
     invoked from within
"eval exec -- $cmd $args >& /dev/null"
     (procedure "run" line 6)
     invoked from within
"run d.mon start=x1"
     invoked from within
"eval run $cmd $args"
     (procedure "runcmd" line 6)
     invoked from within
"runcmd "d.mon start=x$xmon""
     invoked from within
"if ![catch {open "|d.mon -L" r} input] {
       while {[gets $input line] >= 0} {
               if {[regexp -nocase "$xmon.*not running" $line]} {
           run..."
     (procedure "Gm::xmon" line 10)
     invoked from within
"Gm::xmon run v.digit "
     invoked from within
".#menubar.#menubar#menu3.#menubar#menu3#menu1 invoke active"
     ("uplevel" body line 1)
     invoked from within
"uplevel #0 [list $w invoke active]"
     (procedure "tk::MenuInvoke" line 50)
     invoked from within
"tk::MenuInvoke .#menubar.#menubar#menu3.#menubar#menu3#menu1 1"
     (command bound to event)
--Wolf
run v.digit
itself.
Michael
phone: 480-965-6213
fax: 480-965-7671
--Wolf
Michael
phone: 480-965-6213
fax: 480-965-7671
--Wolf
grass5 mailing list
grass5@grass.itc.it
Wolf,
Would you try simply running it from the command line.
D.mon x0
V.digit myexistingmap
(where myexistingmap is a vector map you already have), then try
D.mon x0
V.digit -n mynewmap
(where mynewmap is the name of a vector map that *doesn't* exist)
Thanks
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Thu, 4 May 2006 08:38:21 +0300 (EEST)
     while executing
     invoked from within
     invoked from within
     invoked from within
     invoked from within
     invoked from within
run..."
     invoked from within
     invoked from within
     invoked from within
     invoked from within
--Wolf
run v.digit
itself.
Michael
phone: 480-965-6213
fax: 480-965-7671
--Wolf
Michael
phone: 480-965-6213
fax: 480-965-7671
--Wolf
grass5 mailing list
grass5@grass.itc.it
Wolf,
D.mon x0
segfault:
#0 0xa77c2ca3 in strlen () from /lib/tls/i686/cmov/libc.so.6
#1 0xa78d1789 in Tcl_ExternalToUtfDString () from /usr/lib/libtcl8.4.so.0
#2 0xa7996365 in Tk_MainEx () from /usr/lib/libtk8.4.so.0
#3 0x08052169 in main ()
D.mon x0
V.digit -n mynewmap
segfault
#0 0xa777bca3 in strlen () from /lib/tls/i686/cmov/libc.so.6
#1 0xa788a789 in Tcl_ExternalToUtfDString () from /usr/lib/libtcl8.4.so.0
#2 0xa794f365 in Tk_MainEx () from /usr/lib/libtk8.4.so.0
--Wolf
Thanks. This is very helpful.
There is still something wrong with the underlying v.digit module that needs
to be looked at by the C-folks.
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Thu, 4 May 2006 09:17:32 +0300 (EEST)
Wolf,
D.mon x0
segfault:
D.mon x0
V.digit -n mynewmap
segfault
--Wolf
Hallo and sorry - debuging is not my cup of tea, alas.
[Switching to Thread -1240430368 (LWP 6305)]
0xb7732203 in strlen () from /lib/tls/libc.so.6
(gdb) bt
#0 0xb7732203 in strlen () from /lib/tls/libc.so.6
#1 0xb7840789 in Tcl_ExternalToUtfDString () from /usr/lib/libtcl8.4.so.0
#2 0xb7905365 in Tk_MainEx () from /usr/lib/libtk8.4.so.0
#3 0x08052357 in main (argc=32, argv=0xbf84c134) at main.c:197
debian testing
Jachym
On Wed, May 03, 2006 at 10:23:59PM +0200, Markus Neteler wrote:
On Wed, May 03, 2006 at 10:10:11PM +0200, Jachym Cepicky wrote:
> Hallo,
> Neoprávn?ný p?ístup do pam?ti (SIGSEGV)
> GRASS 6.1.cvs:~ >
> (gdb) run
> 00000094
> (gdb)
Hi Jachym
an dieser Stelle muesstest Du
bt
eingeben, sonst weiss man nicht, wo es passiert.
Debian?
ciao
> D1/5: Map opened
> D2/5: cat_init()
> D5/5: driver_open()
> D5/5: -> opened
> 609097.969406
> D5/5: -> closed
> D5/5: driver_open()
> D5/5: -> opened
> 609097.969406
> D2/5: display_bg()
> D5/5: -> closed
> D5/5: driver_open()
> D5/5: -> opened
> 609097.969406
> D2/5: display_map()
> D5/5: -> closed
> Segmentation fault
> GRASS 6.1.cvs:~ >
> I hope, this helps.
> Jachym
> > Michael
> > phone: 480-965-6213
> > fax: 480-965-7671
> > > Hi,
> > > --Wolf
> > _______________________________________________
> > grass5 mailing list
> > grass5@grass.itc.it
> Jachym Cepicky
> OFFICE:
> GDF-Hannover
> Mengendamm 16d
> 30177 Hannover
> Germany
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
Threaded Tcl + C is hard for anybody.
A dumb but effective method is to start adding
  printf(" -- here line 1234\n");
in the C code and
  puts {"here line 1234"}
in the tcl code and see if you can narrow down exactly where it breaks.
When you find that you can print the variables before the call to
investiatge.
gdb hints: [compile with -g and without optimization or stripping]
(gdb) bt f # outputs all variable values when it broke
(gdb) l # (lowercase "L") shows where in the source code you are
(gdb) frame 0 # switches to that function (eg #0 strlen())
(gdb) p <name> # print the value of some variable
see also doc/debugging.txt in the source code.
(gdb) bt
#/usr/lib/libtcl8.4.so.0 2 0xb7905365 in Tk_MainEx () from
#/usr/lib/libtk8.4.so.0 3 0x08052357 in main (argc=32,
#argv=0xbf84c134) at main.c:197
debian testing
It's all fine for me on Debian/stable tcl/tk 8.4
Can you try compiling with tcl8.3-dev and tk8.3-dev and see if you get
the same result?
Hamish
ps - please cc relevant info to the bug report,
  https://intevation.de/rt/webrt?serial_num=4380
