[GRASS5] v.digit topology question
Experimenting with GRASS 5.7, I've managed to make a great vector shape using v.digit. I very much like the interface--much simpler than ArcView/ArcGIS, and certainly much easier than the v.digit of GRASS 5.0.x (although with fewer options it seems).
However, something is driving me crazy. I've probably missed something, but hope someone can help me. I've digitized a boundary, but can't figure out how to turn it into an area. When I do a right-click after digitizing a shape, the implication is that it will close a polygon, creating an area. It doesn't seem to do this,however.
I've tried inserting a centroid, doing various versions of v.clean, v.build.polylines, and v.build to no avail. After exporting into ascii, cleaning up some tiny segments produced at line intersections (how produced I don't know, perhaps by v.clean), and reimporting, I managed to get it down to a single polyline boundary. But I still can't convert it to an area.
After several hours of futzing around, I give up. Can anyone tell me how to do this?
Also, please note that when I do a v.out.ascii on this boundary file, it creates a file that GRASS 5.0.x won't parse. I assume that it has something to do with assigning "B" labels for boundary vertices, rather than "A" or "L" labels, but I don't know for sure. I haven't yet tried exporting in version 4 format. Maybe that will work.
____________________
C. Michael Barton, Professor
Department of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
Right-click does not close the polygon (yes, 'Close line' prompt is not the best).
To do this, new check box ('Close polygon') must be added to interface.
I want to add also option 'Insert automatically new centroid'.
These two options should make digitizing of isolated areas easier.
Now, if you want to create new area as one closed boundary, you have to digitize
the boundary and then to snap last vertex to the first vertex.
Boundary and crosses at the ends must become green not red.
BTW, there is a bug in vector library and centroid colors are not updated
properly if boundary is closed, opened etc.
it to an area.
With v.digit, it should be possible to create clean data. To make clean
data in v.digit is better than to make bad data and run v.clean later.
Vector ascii format is changed, use -o (old) option to get 5.0 format.
On Wednesday, October 29, 2003, at 10:01 PM, John Gillette wrote:
> v.type input=map_in output=map_out type=line,boundary
Thanks for the advice. I thought about this and almost tried it but did
not. The reason is that GRASS considers my closed polygon object to be
a boundary, but not an area. I want a filled area, not just the
boundary of an area. v.type does not have an option to make a boundary
an area.
Most probably, the polygon is not closed. What color is the boundary in v.digit?
Radim
