Hamish wrote:
> Hi,
> I'm looking to do some v.in.ascii updates, I thought I'd trawl for
> comments first.. most deal with format=point mode.
> Fairly straight forward updates:
> + update to use G_getl2() to make MacOS9 ascii import work.
done. (point mode only)
> + add skip= option to skip any header lines when format=point
> (e.g. column headings in cvs file)
> + add a -s flag to write those skipped header lines to the map's
> meta-data hist file (v.info -h).
I think that you can simply write that to history without complicating
the module with new flag?
good point, done. (point mode only)
> Debatable updates:
> ? skip any line starting with a '#' in input file.
> (could silently ignore data..??)
done & documented in help page. (point mode only?)
> ? skip blank lines in input file.
> (currently extra newlines at EOF break import of points)
User must be warn if there are errors in the file, empty line may be
error in input. There should be probably a flag for shuch skipping.
not done. I'd like to ignore blank lines if they happen at end of file,
but don't see an easy way of doing that. I agree that blank lines mid-
file is an error.
Maybe it should be done in a GUI? Normal GRASS user can use
cat file | grap -v "^$" | grep -v "#"
I think that's a pretty serious definition of "Normal GRASS user".
> ? strip "quotes" from both ends of varchar input.
TODO.
> ? rename format=standard to format=grass as format=point is
> default,
> so standard mode is non-standard. Confusing! I'll fix any
> scripts/.
ABSOLUTELY FORBIDDEN! The module options and behaviour MUST NOT change
during the 6.x line. That applies to all modules and all developers
without exceptions.
right. left as is.
Thanks to all for comments, they helped.
Hash (#) comments and skip= are for points mode only right now. Worth
putting in standard mode too? (skip doesn't make much sense there, but
might be a good way to write stuff to the history file?)
Please report any problems.
Please report if the massive input points memory leak is fixed/same/
worse. (e.g. LIDAR)
Mac people please report if .csv files saved in Excel-for-OSX work.
Hamish
