--- Hamish <hamish_nospam@yahoo.com> wrote:
I'm looking to do some v.in.ascii updates, I thought
I'd trawl for
comments first.. most deal with format=point mode.Fairly straight forward updates:
+ update to use G_getl2() to make MacOS9 ascii
import work.+ add skip= option to skip any header lines when
format=point
(e.g. column headings in cvs file)+ add a -s flag to write those skipped header lines
to the map's
meta-data hist file (v.info -h).Debatable updates:
? skip any line starting with a '#' in input file.
(could silently ignore data..??)? skip blank lines in input file.
(currently extra newlines at EOF break import of
points)? strip "quotes" from both ends of varchar input.
? rename format=standard to format=grass as
format=point is default,
so standard mode is non-standard. Confusing! I'll
fix any scripts/.You can expect me to go ahead and do all these
things if noone objects.Hamish
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Also if can puts an indicative for the format to
import the values "columns='variable double f8.2' "
for when it be used with other instruction put excatly
the format that was reading; p.e. "d.vect -c file
display=attr attrcol=variable"
LCA Miguel A. Altamirano del C.
"Los Mexicanos llevamos la fiesta en la garganta"
Tel. 01(232)32 45208
La belleza de la meteorología radica en saber
pronosticarla y no simplemente en estudiarla
(Miguel A. Altamirano 28-5-00)
_________________________________________________________
Do You Yahoo!?
Información de Estados Unidos y América Latina, en Yahoo! Noticias.
Visítanos en http://noticias.espanol.yahoo.com
