[GRASS5] v.in.dwg, Cannot open database
Anyone recognize this one? I'm using the older OpenDWG Toolkit (haven't figured out the newer DWGDirect file structure yet).
GRASS 5.7.cvs:~ > v.in.dwg input=/Volumes/disk2/data2/ccgis/cc1.dxf output=Boundary layers=Boundary
WARNING: The vector 'Boundary' already exists and will be overwritten.
dbmi: db_open_database() not implemented
WARNING: Cannot open database
          '/usr/local/share/grassdata/cecr_utm/ccgis/dbf/'
ERROR: Cannot open database /usr/local/share/grassdata/cecr_utm/ccgis/dbf/
        by driver dbf
GRASS 5.7.cvs:~ >
Kirk R. Wythers
Dept. of Forest Resources
University of Minnesota
email: kwythers@umn.edu
tel: 612.625.2261
fax: 612.625.5212
>> overwritten.
>> by driver dbf
>> GRASS 5.7.cvs:~ >
> Does 'db.connect -p' work?
Gives:
GRASS 5.7.cvs:~ > db.connect -p
driver:(null)
database:(null)
Ok, you need to tell it what kind of database you want the attribute
data to be stored in, e.g.:
db.connect driver=dbf database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'
Hamish
overwritten.
        by driver dbf
GRASS 5.7.cvs:~ >
Gives:
driver:(null)
database:(null)
If I issue the db.connect command to the location and mapset that I'm trying to read the dxf file into, it correctly shows that there is nothing as of yet in the directory dbf:
GRASS 5.7.cvs:~ > db.connect driver=dbf database=~/grassdata/cecr_utm/ccgis/dbf/
driver:dbf
database:/Users/kirkw/grassdata/cecr_utm/ccgis/dbf/
  However, double checking with the spearfish dataset, it correctly shows the soils database.
GRASS 5.7.cvs:~ > db.connect driver=dbf database=~/grassdata/spearfish57/PERMANENT/dbf/soils.dbf
driver:dbf
So it looks like db.connect works
Kirk R. Wythers
tel: 612.625.2261
fax: 612.625.5212
