[GRASS5] v.in.ogr PRJ issue
I tried to import the sample soils map from
PostGIS (1.1.x, on PG 8.0.x):
ogrinfo "PG:host=localhost dbname=postgis" soils | head -25
INFO: Open of `PG:host=localhost dbname=postgis'
using driver `PostgreSQL' successful.
Layer name: soils
Geometry: Polygon
Feature Count: 737
Extent: (589443.750000, 4913923.000000) - (609546.187500, 4928106.000000)
Layer SRS WKT:
PROJCS["UTM Zone 13, Northern Hemisphere",
    GEOGCS["clark66",
        DATUM["North_American_Datum_1927",
            SPHEROID["clark66",6378206.4,294.9786982]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-105],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["meter",1]]
FID Column = ogc_fid
Geometry Column = wkb_geometry
cat: Integer (0.0)
label: String (0.0)
But GRASS tells me:
v.in.ogr dsn="PG:host=localhost dbname=postgis" layer=soils output=soils_pg type=boundary,centroid
ERROR: Projection of dataset does not appear to match current location.
       LOCATION PROJ_INFO is:
       datum: nad27
       nadgrids: conus
       proj: utm
       ellps: clark66
       a: 6378206.4000000004
       es: 0.0067686580
       f: 294.9786982000
       zone: 13
       cellhd.proj = 0 (unreferenced/unknown)
       You can use the -o flag to v.in.ogr to override this check.
       Consider to generate a new location with 'location' parameter from
       input data set.
It seems that there are still definition issues with PROJ.
any ideas?
I don't know the answer here Markus, but I have noticed this same message on much of the work that I have been doing for the last few weeks with grass and postgres. Since the imports from v.in.ogr -o can be displayed properly, I have been ignoring the message.
Kirk
On Feb 27, 2006, at 9:50 AM, Markus Neteler wrote:
Layer name: soils
Geometry: Polygon
Feature Count: 737
Layer SRS WKT:
    GEOGCS["clark66",
    UNIT["meter",1]]
cat: Integer (0.0)
label: String (0.0)
But GRASS tells me:
       datum: nad27
       nadgrids: conus
       proj: utm
       ellps: clark66
       es: 0.0067686580
       f: 294.9786982000
       zone: 13
       input data set.
any ideas?
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Hello Markus,
On Mon, 27 Feb 2006 16:50:05 +0100 Markus Neteler <neteler@itc.it>
wrote:
Layer name: soils
Geometry: Polygon
Feature Count: 737
4928106.000000) Layer SRS WKT:
    GEOGCS["clark66",
    UNIT["meter",1]]
cat: Integer (0.0)
label: String (0.0)
But GRASS tells me:
output=soils_pg type=boundary,centroid ERROR: Projection of dataset
       datum: nad27
       nadgrids: conus
       proj: utm
       ellps: clark66
       es: 0.0067686580
       f: 294.9786982000
       zone: 13
from input data set.
any ideas?
I have found the opposite behaviour. I can import any dataset with
different proj-information inside the spearfish60-location...
Something is messed up there.
Could anybody have a look into this?
Best
  Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
