[GRASS5] v.in.ogr with spatial
Dear developers,
I am trying to import some vector-datasets into GRASS via v.in.ogr. The
spatial switch does not work as expected, I guess.
My trys:
g.region -p
projection: 99 (Transverse Mercator)
zone: 0
datum: potsdam
ellipsoid: bessel
north: 5800710
south: 5788320
west: 3427050
east: 3444000
This is my default region, where the dataset fits inside. I only need
parts of this shape so I try to import only this giving the 4
corner-coordinates which include my needed features:
v.in.ogr -o dsn=PG:dbname=postgis layer=gruen
spatial=3436830,5794290,3439770,5796780 out=test_spatial
But after this all featuers including in the dataset were imported.
Is this the correct usage of the spatial switch ?!
Thanks for your help
  Stephan Holl
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
20:06:58 up 3:55, 1 user, load average: 0.02, 0.07, 0.16
Hi Stephan,
the spatial filter in v.in.ogr is fixed in CVS.
On Wed, Mar 17, 2004 at 08:14:38PM +0100, Stephan Holl wrote:
Dear developers,
My trys:
g.region -p
zone: 0
datum: potsdam
ellipsoid: bessel
north: 5800710
south: 5788320
west: 3427050
east: 3444000
  Stephan Holl
Stephan Holl
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
Hello Markus,
thanks a lot for this faaast fix!
That's how it _should_ work :slight_smile: I will give it a try to make it work.
Gruß
  Stephan
Stephan Holl
16:42:47 up 1:56, 1 user, load average: 0.10, 0.06, 0.02
