Hallo,
couple of weeks ago, I wrote about segmetation fault by the v.out.ascii and
NVIZ modules in current GRASS 5.7. Now days, I tryed to recompile GRASS to
see, what happend. There is still segfault in v.out.ascii.
I use debian gnu linux sarge. Before I started, I run rm -rf on
/usr/local/grass-5.7.cvs/ /usr/src/grass57 ~/.grassrc6 and I improved my
/etc/ld.so.conf like this:
/usr/X11R6/lib
/usr/local/lib
/usr/lib/atlas
/usr/local/grass-5.7.cvs/lib
/usr/lib
and run ldconfig
cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 15
model : 2
model name : Intel(R) Celeron(R) CPU 2.00GHz
stepping : 9
cpu MHz : 2019.960
cache size : 128 KB
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 2
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe cid
bogomips : 4005.88
cat /proc/meminfo
MemTotal: 1557528 kB
MemFree: 1260100 kB
Buffers: 29436 kB
Cached: 169520 kB
SwapCached: 0 kB
Active: 176884 kB
Inactive: 89052 kB
HighTotal: 655296 kB
HighFree: 410112 kB
LowTotal: 902232 kB
LowFree: 849988 kB
SwapTotal: 1518100 kB
SwapFree: 1518100 kB
Dirty: 260 kB
Writeback: 0 kB
Mapped: 107152 kB
Slab: 14104 kB
Committed_AS: 157320 kB
PageTables: 980 kB
VmallocTotal: 114680 kB
VmallocUsed: 26028 kB
VmallocChunk: 84028 kB
I configured GRASS like this:
CFLAGS="-g -Wall" ./configure --with-cxx --with-postgres-includes=/usr/include/postgresql/ --with-gdal=/usr/bin/gdal-config --with-proj --with-motif --with-glw --with-nls --with-freetype --with-freetype-includes=/usr/include/freetype2/ --with-tcltk-includes=/usr/include/tcl8.3/
And I got:
GRASS is now configured for: i686-pc-linux-gnu
Source directory: /usr/src/grass/grass51
Build directory: /usr/src/grass/grass51
Installation directory: /usr/local/grass-5.7.cvs
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -g -Wall
C++ compiler: c++ -g -O2
FORTRAN compiler:
Building shared libraries: yes
NVIZ: yes
X11 support: yes
JPEG support: yes
TIFF support: yes
PNG support: yes
Tcl/Tk support: yes
PostgreSQL support: yes
MySQL support: no
OpenGL(R) support: yes
ODBC support: no
FFTW support: yes
BLAS support: no
LAPACK support: no
Motif support: yes
FreeType support: yes
GLw support: yes
NLS support: yes
Readline support: no
C++ support: yes
openDWG support: no
GDAL support: yes
OGR support: yes
then I run make and error.log says:
GRASS GIS compilation log
Started compilation: Pá led 7 18:42:50 CET 2005
Errors in:
Finished compilation: Pá led 7 19:20:59 CET 2005
In GRASS:
GRASS 5.7.cvs:~ > echo "-592854.20115798|-1149140.62500086"| v.in.ascii out=tmp
Maximum input row length: 35
Maximum number of columns: 2
Minimum number of columns: 2
Building topology ...
1 primitives registered
Building areas: 100%
0 areas built
0 isles built
Attaching islands: Attaching centroids: 100%
Topology was built.
Number of nodes : 1
Number of primitives: 1
Number of points : 1
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
GRASS 5.7.cvs:~ > v.out.ascii tmp
Segmentation fault
GRASS 5.7.cvs:~ >
NVIZ is running well now.
I tryed the memtest86, it looked good.
Please, could comeone tell me, what to do? Google says nothing :-/
Thank you a lot
Jachym
P.S.
Now there is strace output:
GRASS 5.7.cvs:~ > strace v.out.ascii tmp
execve("/usr/local/grass-5.7.cvs/bin/v.out.ascii", ["v.out.ascii", "tmp"], [/* 40 vars */]) = 0
uname({sys="Linux", node="trava", ...}) = 0
brk(0) = 0x804b000
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40017000
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.preload", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/cmov/libgrass_vect.so", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/cmov", 0xbfffef58) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libgrass_vect.so", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx", {st_mode=S_IFDIR|S_ISGID|0755, st_size=4096, ...}) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/cmov/libgrass_vect.so", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass-5.7.cvs/lib/tls/i686/cmov", 0xbfffef58) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libgrass_vect.so", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass-5.7.cvs/lib/tls/i686", {st_mode=S_IFDIR|S_ISGID|0755, st_size=4096, ...}) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/mmx/cmov/libgrass_vect.so", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass-5.7.cvs/lib/tls/mmx/cmov", 0xbfffef58) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/mmx/libgrass_vect.so", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass-5.7.cvs/lib/tls/mmx", 0xbfffef58) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/cmov/libgrass_vect.so", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass-5.7.cvs/lib/tls/cmov", 0xbfffef58) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libgrass_vect.so", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass-5.7.cvs/lib/tls", {st_mode=S_IFDIR|S_ISGID|0755, st_size=4096, ...}) = 0
open("/usr/local/grass-5.7.cvs/lib/i686/mmx/cmov/libgrass_vect.so", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass-5.7.cvs/lib/i686/mmx/cmov", 0xbfffef58) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/i686/mmx/libgrass_vect.so", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass-5.7.cvs/lib/i686/mmx", 0xbfffef58) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/i686/cmov/libgrass_vect.so", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass-5.7.cvs/lib/i686/cmov", 0xbfffef58) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/i686/libgrass_vect.so", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass-5.7.cvs/lib/i686", 0xbfffef58) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/mmx/cmov/libgrass_vect.so", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass-5.7.cvs/lib/mmx/cmov", 0xbfffef58) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/mmx/libgrass_vect.so", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass-5.7.cvs/lib/mmx", 0xbfffef58) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/cmov/libgrass_vect.so", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass-5.7.cvs/lib/cmov", 0xbfffef58) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libgrass_vect.so", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200\210"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=1958836, ...}) = 0
old_mmap(NULL, 216732, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40018000
old_mmap(0x4004c000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x34000) = 0x4004c000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libgrass_dig2.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libgrass_dig2.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libgrass_dig2.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libgrass_dig2.so", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0p4\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=810835, ...}) = 0
old_mmap(NULL, 78936, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4004d000
old_mmap(0x40060000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x13000) = 0x40060000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libgrass_dgl.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libgrass_dgl.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libgrass_dgl.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libgrass_dgl.so", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\240=\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=266234, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40061000
old_mmap(NULL, 103320, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40062000
old_mmap(0x4007b000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x19000) = 0x4007b000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libgrass_rtree.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libgrass_rtree.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libgrass_rtree.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libgrass_rtree.so", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0P\20\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=70199, ...}) = 0
old_mmap(NULL, 23724, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4007c000
old_mmap(0x40081000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x4000) = 0x40081000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libgrass_linkm.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libgrass_linkm.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libgrass_linkm.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libgrass_linkm.so", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\260\10"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=44487, ...}) = 0
old_mmap(NULL, 7924, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40082000
old_mmap(0x40083000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x40083000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libgrass_dbmiclient.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libgrass_dbmiclient.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libgrass_dbmiclient.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libgrass_dbmiclient.so", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0`2\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=573613, ...}) = 0
old_mmap(NULL, 38272, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40084000
old_mmap(0x4008d000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x8000) = 0x4008d000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libgrass_dbmibase.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libgrass_dbmibase.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libgrass_dbmibase.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libgrass_dbmibase.so", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\240P\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=772906, ...}) = 0
old_mmap(NULL, 60752, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4008e000
old_mmap(0x4009c000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xd000) = 0x4009c000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libgdal.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libgdal.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libgdal.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libgdal.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=56819, ...}) = 0
old_mmap(NULL, 56819, PROT_READ, MAP_PRIVATE, 3, 0) = 0x4009d000
close(3) = 0
open("/usr/lib/libgdal.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0@\301\7"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=3222912, ...}) = 0
old_mmap(NULL, 3579008, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x400ab000
old_mmap(0x40347000, 491520, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x29b000) = 0x40347000
old_mmap(0x403bf000, 351360, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x403bf000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libgrass_gis.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libgrass_gis.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libgrass_gis.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libgrass_gis.so", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\20\303"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=2956606, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40415000
old_mmap(NULL, 609980, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40416000
old_mmap(0x4046b000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x54000) = 0x4046b000
old_mmap(0x4046d000, 253628, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x4046d000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libgrass_datetime.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libgrass_datetime.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libgrass_datetime.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libgrass_datetime.so", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\360\30"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=82502, ...}) = 0
old_mmap(NULL, 35808, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x404ab000
old_mmap(0x404b3000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x7000) = 0x404b3000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libz.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libz.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libz.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libz.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libz.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200\27"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=67468, ...}) = 0
old_mmap(NULL, 70528, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x404b4000
old_mmap(0x404c5000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x10000) = 0x404c5000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/tls/i686/cmov/libm.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\00005\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=134144, ...}) = 0
old_mmap(NULL, 136640, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x404c6000
old_mmap(0x404e7000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x20000) = 0x404e7000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/tls/i686/cmov/libc.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\360Y\1"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=1253924, ...}) = 0
old_mmap(NULL, 1260140, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x404e8000
old_mmap(0x40611000, 32768, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x129000) = 0x40611000
old_mmap(0x40619000, 10860, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40619000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libodbc.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libodbc.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libodbc.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libodbc.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libodbc.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\20<\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=488464, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x4061c000
old_mmap(NULL, 487564, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4061d000
old_mmap(0x40690000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x73000) = 0x40690000
old_mmap(0x40694000, 140, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40694000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libxerces-c.so.21", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libxerces-c.so.21", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libxerces-c.so.21", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libxerces-c.so.21", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libxerces-c.so.21", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\204\351"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=2593344, ...}) = 0
old_mmap(NULL, 2600044, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40695000
old_mmap(0x408b1000, 385024, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x21b000) = 0x408b1000
old_mmap(0x4090f000, 3180, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x4090f000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libjasper-1.701.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libjasper-1.701.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libjasper-1.701.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libjasper-1.701.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libjasper-1.701.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0 r\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=288776, ...}) = 0
old_mmap(NULL, 313404, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40910000
old_mmap(0x40954000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x44000) = 0x40954000
old_mmap(0x40957000, 22588, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40957000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libmfhdf.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libmfhdf.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libmfhdf.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libmfhdf.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libmfhdf.so.4", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\0\\\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=133840, ...}) = 0
old_mmap(NULL, 137184, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4095d000
old_mmap(0x4097d000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x20000) = 0x4097d000
old_mmap(0x4097e000, 2016, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x4097e000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libdf.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libdf.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libdf.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libdf.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libdf.so.4", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0p\2\1\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=482928, ...}) = 0
old_mmap(NULL, 649164, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4097f000
old_mmap(0x409f3000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x74000) = 0x409f3000
old_mmap(0x409f5000, 165836, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x409f5000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libungif.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libungif.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libungif.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libungif.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libungif.so.4", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\340\25"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=28484, ...}) = 0
old_mmap(NULL, 31552, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40a1e000
old_mmap(0x40a25000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x6000) = 0x40a25000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libjpeg.so.62", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libjpeg.so.62", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libjpeg.so.62", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libjpeg.so.62", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libjpeg.so.62", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\300$\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=120952, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40a26000
old_mmap(NULL, 119916, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40a27000
old_mmap(0x40a44000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1d000) = 0x40a44000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libtiff.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libtiff.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libtiff.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libtiff.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libtiff.so.4", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\340C\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=317616, ...}) = 0
old_mmap(NULL, 317600, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40a45000
old_mmap(0x40a91000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x4c000) = 0x40a91000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libpng12.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libpng12.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libpng12.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libpng12.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libpng12.so.0", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\220\\\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=147224, ...}) = 0
old_mmap(NULL, 150228, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40a93000
old_mmap(0x40ab7000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x23000) = 0x40ab7000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libnetcdf.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libnetcdf.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libnetcdf.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libnetcdf.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libnetcdf.so.3", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\344g\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=141936, ...}) = 0
old_mmap(NULL, 141336, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40ab8000
old_mmap(0x40ada000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x22000) = 0x40ada000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libcfitsio.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libcfitsio.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libcfitsio.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libcfitsio.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libcfitsio.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0000/\1\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=1019536, ...}) = 0
old_mmap(NULL, 1493352, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40adb000
old_mmap(0x40bd2000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xf7000) = 0x40bd2000
old_mmap(0x40bd4000, 473448, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40bd4000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/tls/i686/cmov/libpthread.so.0", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\0G\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=82632, ...}) = 0
old_mmap(NULL, 64932, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40c48000
old_mmap(0x40c55000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xd000) = 0x40c55000
old_mmap(0x40c56000, 7588, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40c56000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/tls/i686/cmov/libdl.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\260\32"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=9872, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40c58000
old_mmap(NULL, 8632, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40c59000
old_mmap(0x40c5b000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x2000) = 0x40c5b000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libpq.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libpq.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libpq.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libpq.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libpq.so.3", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0pX\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=127184, ...}) = 0
old_mmap(NULL, 126272, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40c5c000
old_mmap(0x40c7a000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1e000) = 0x40c7a000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libstdc++.so.5", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libstdc++.so.5", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libstdc++.so.5", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libstdc++.so.5", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libstdc++.so.5", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200\301"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=737816, ...}) = 0
old_mmap(NULL, 761536, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40c7b000
old_mmap(0x40d1a000, 90112, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x9e000) = 0x40d1a000
old_mmap(0x40d30000, 20160, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40d30000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libgcc_s.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\20\30\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=32324, ...}) = 0
old_mmap(NULL, 35336, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40d35000
old_mmap(0x40d3d000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x7000) = 0x40d3d000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libltdl.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libltdl.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libltdl.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libltdl.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libltdl.so.3", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0 \24\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=25164, ...}) = 0
old_mmap(NULL, 28276, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40d3e000
old_mmap(0x40d44000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x5000) = 0x40d44000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libssl.so.0.9.7", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libssl.so.0.9.7", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libssl.so.0.9.7", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libssl.so.0.9.7", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/i686/cmov/libssl.so.0.9.7", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\0\205\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=198576, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40d45000
old_mmap(NULL, 199344, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40d46000
old_mmap(0x40d74000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x2e000) = 0x40d74000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libcrypto.so.0.9.7", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libcrypto.so.0.9.7", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libcrypto.so.0.9.7", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libcrypto.so.0.9.7", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/i686/cmov/libcrypto.so.0.9.7", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0p\300\2"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=1029672, ...}) = 0
old_mmap(NULL, 1043608, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40d77000
old_mmap(0x40e61000, 73728, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xea000) = 0x40e61000
old_mmap(0x40e73000, 11416, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40e73000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libkrb5.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libkrb5.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libkrb5.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libkrb5.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libkrb5.so.3", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\240\372"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=425800, ...}) = 0
old_mmap(NULL, 425224, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40e76000
old_mmap(0x40edc000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x66000) = 0x40edc000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libcrypt.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libcrypt.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libcrypt.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libcrypt.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/tls/i686/cmov/libcrypt.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\360\t\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=18844, ...}) = 0
old_mmap(NULL, 181660, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40ede000
old_mmap(0x40ee3000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x4000) = 0x40ee3000
old_mmap(0x40ee4000, 157084, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40ee4000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libresolv.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libresolv.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libresolv.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libresolv.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/tls/i686/cmov/libresolv.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\220)\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=64924, ...}) = 0
old_mmap(NULL, 73640, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40f0b000
old_mmap(0x40f1a000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xf000) = 0x40f1a000
old_mmap(0x40f1b000, 8104, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40f1b000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/tls/i686/cmov/libnsl.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0 <\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=73304, ...}) = 0
old_mmap(NULL, 80544, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40f1d000
old_mmap(0x40f2e000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x11000) = 0x40f2e000
old_mmap(0x40f2f000, 6816, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40f2f000
close(3) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40f31000
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libk5crypto.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libk5crypto.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libk5crypto.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libk5crypto.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libk5crypto.so.3", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\2205\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=138664, ...}) = 0
old_mmap(NULL, 138688, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40f32000
old_mmap(0x40f53000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x21000) = 0x40f53000
close(3) = 0
open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libcom_err.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/i686/libcom_err.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/tls/libcom_err.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/lib/libcom_err.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libcom_err.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\230\n\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=5900, ...}) = 0
old_mmap(NULL, 8996, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40f54000
old_mmap(0x40f56000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1000) = 0x40f56000
close(3) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40f57000
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40f58000
set_thread_area({entry_number:-1 -> 6, base_addr:0x40f57d80, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}) = 0
munmap(0x4009d000, 56819) = 0
set_tid_address(0x40f57dc8) = 6614
rt_sigaction(SIGRTMIN, {0x40c4c660, , SA_SIGINFO}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN], NULL, 8) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM_INFINITY}) = 0
brk(0) = 0x804b000
brk(0x806c000) = 0x806c000
open("/tmp/grass6-jachym-6519/gisrc", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=88, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x4009d000
read(3, "GISDBASE: /home/jachym/grassdata"..., 4096) = 88
read(3, "", 4096) = 0
close(3) = 0
munmap(0x4009d000, 4096) = 0
access("/home/jachym/grassdata/krtiny", F_OK) = 0
stat64("/home/jachym/grassdata/krtiny/mapserv", {st_mode=S_IFDIR|0777, st_size=4096, ...}) = 0
getuid32() = 1000
geteuid32() = 1000
getuid32() = 1000
geteuid32() = 1000
umask(022) = 022
open("/usr/lib/locale/locale-archive", O_RDONLY|O_LARGEFILE) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=496848, ...}) = 0
mmap2(NULL, 496848, PROT_READ, MAP_PRIVATE, 3, 0) = 0x40f59000
close(3) = 0
open("/usr/share/locale/locale.alias", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=2539, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40fd3000
read(3, "# Locale name alias data base.\n#"..., 4096) = 2539
close(3) = 0
munmap(0x40fd3000, 4096) = 0
open("/usr/local/grass-5.7.cvs/locale/en_US/LC_MESSAGES/grasslibs.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/local/grass-5.7.cvs/locale/en/LC_MESSAGES/grasslibs.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
--- SIGSEGV (Segmentation fault) @ 0 (0) ---
+++ killed by SIGSEGV +++
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://www.fle.czu.cz/~jachym/gnupg_public_key/
