1) New option 'format' specifies if ascii file is 'standard' or 'point'.
2) The modules can read/write both format form file (input=path to file) or stdin/stdout.
3) coordinates order was changed to X Y [Z] except 'v.out.ascii -o' for standard format.
4) 'v.out.ascii -o' writes to dig_ascii/
after running the latest v.in.ascii on a "new" style vector ascii file:
VERTI:
L 2 1
x1 y1
x2 y2
1 1
etc.
I get the following [v.in.garmin]:
Importing with v.in.ascii
Building topology ...
1 primitives registered
0 areas built 0%
0 isles built
Topology was built.
Number of nodes : 2
Number of primitives: 1
Number of points : 0
Number of lines : 1
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
v.in.garmin: line vector "test5novRTE@mapset" successfully created
but when I do 'v.info test5novRTE', I get:
ERROR: Cannot open old vector test5novRTE@mapset on level 2
Try the same directly with v.in.ascii.
What files are in vectors directory.
Does it help to run v.build?
Radim
VERTI:
L 2 1
x1 y1
x2 y2
1 1
etc.
0 areas built 0%
0 isles built
Topology was built.
Number of nodes : 2
Number of lines : 1
Number of areas : 0
Number of isles : 0
This sounds like it makes the v.in.asciipoints script I wrote for GRASS 5.7
obsolete. Is that correct? (It allowed a user to select an ascii file for
input into v.in.ascii rather than making them do a "cat <file> |" from the
command line).
Michael
On 11/4/04 10:52 AM, "Radim Blazek" <blazek@itc.it> wrote:
WARNING: v.in.ascii and v.out.ascii were changed:
or stdin/stdout.
standard format.
Radim
______________________________
School of Human, Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
command line).
Yes.
Radim
Michael
or stdin/stdout.
standard format.
Radim
USA
>VERTI:
>L 2 1
> x1 y1
> x2 y2
> 1 1
>etc.
>0 areas built 0%
>0 isles built
>Topology was built.
>Number of nodes : 2
>Number of lines : 1
>Number of areas : 0
>Number of isles : 0
Radim:
Same result. (sample file & DEBUG=5 stderr log attached; stdout is as above)
also
G57> d.vect test8novTRK
WARNING: Cannot display areas, topology not available
[input file (eg attached) only contains lines, they draw ok]
$ ls vector/test8novTRK/
coor dbln head hist
Yes. After running v.build everything works as expected.
[not attached file..]
G57> v.build test8novTRK
152 primitives registered
0 areas built 8%
0 isles built
Topology was built.
Number of nodes : 240
Number of primitives: 152
Number of lines : 152
Number of areas : 0
Number of isles : 0
[0 areas built 8%] ???
Then these files exist:
G57> ls vector/test8novTRK/
cidx coor dbln head hist sidx topo
thanks, I think v.in|out.ascii modes are much less confusing now.
No idea, for me it works, it seems that topology
is built but it is not saved to files.
Vect_build ( &Map, stdout ); Vect_close ( &Map );
in v.in.ascii is the same as in all other modules.
Radim
Hamish wrote:
Hamish:
VERTI:
L 2 1
x1 y1
x2 y2
1 1
etc.
0 areas built 0%
0 isles built
Topology was built.
Number of nodes : 2
Number of lines : 1
Number of areas : 0
Number of isles : 0
Radim:
also
coor dbln head hist
0 areas built 8%
0 isles built
Topology was built.
Number of areas : 0
Number of isles : 0
