[GRASS5] v.out.ogr and v.external does not work
Hallo,
I try to "v.out.ogr" some polygon map from GRASS to PosgreSQL (postgis),
which I do trough
GRASS: ~> v.out.ogr input=det@idrisi type=area dsn="PG:dbname=krtiny" olayer=det format=PostgreSQL
After that, two tables (one table and one sequence) are created:
psql=> \d det
   Column | Type | Modifikátory
ogc_fid | integer | not null default nextval('public.det_ogc_fid_seq'::text)
wkb_geometry | geometry |
cat | integer |
cislo | integer |
plocha | double precision |
vymera | double precision |
kvalita | integer |
katastr | character varying |
ku_kod | integer |
sk_parc | character varying |
oddeleni | integer |
psql=> Sequence "public.det_ogc_fid_seq"
krtiny=> Sequence "public.det_ogc_fid_seq"
    Sloupec | Typ | Typ | Vlastník
sequence_name | name | tabulka | jachym
last_value | bigintseq | sequence | jachym
increment_by | bigintmns | tabulka | jachym
max_value | bigint | tabulka | jachym
min_value | bigint | sequence | jachym
cache_value | bigintys | tabulka | jachym
log_cnt | bigint | tabulka | jachym
is_cycled | boolean | sequence | jachym
when I try to "v.extrude" this table, I get following error:
GRASS: ~> v.external dsn="PG: dbname=krtiny" out=det layer=det
ERROR 1: ERROR: column "fid" does not exist
ERROR 1: ERROR: column "ogr_fid" does not exist
Vytváøím topologii ...
Feature: 0
Topologie byla vytvoøena.
Poèet uzlù : 0
Poèet primitiv : 0
Poèet bodù : 0
Poèet linií : 0
Poèet hranic : 0
Poèet centroidù : 0
Poèet ploch : 0
Poèet ostrovù : 0
GRASS: ~> d.vect det
WARNING: 'vector/det/head' was found in more mapsets (also found in
         stromy).
The bounding box of the map outside current region, nothing displayed.
What to do?
Thanks
Jachym
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/
OFFICE:
Department of Geoinformation Technologies
LDF MZLU v Brnì
Zemìdìlská 3
613 00 Brno
e-mail: xcepicky@node.mendelu.cz
URL: http://mapserver.mendelu.cz
Tel.: +420 545 134 514
I upgraded to postgis-1.1.1 and seems to work
only error, i get is
but it is running so I'll let it be
jachym
On Fri, Mar 10, 2006 at 03:58:58PM +0100, Jachym Cepicky wrote:
Hallo,
which I do trough
psql=> \d det
cat | integer |
cislo | integer |
kvalita | integer |
ku_kod | integer |
Feature: 0
Poèet uzlù : 0
Poèet primitiv : 0
Poèet bodù : 0
Poèet linií : 0
Poèet hranic : 0
Poèet centroidù : 0
Poèet ploch : 0
Poèet ostrovù : 0
         stromy).
What to do?
Thanks
Jachym
Jachym Cepicky
OFFICE:
LDF MZLU v Brnì
Zemìdìlská 3
613 00 Brno
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Jachym Cepicky
OFFICE:
LDF MZLU v Brnì
Zemìdìlská 3
613 00 Brno
Jachym,
I have already implemented an auto-detector of
the FID column, but it doesn't work yet.
Asap I hope to have it in CVS.
Then these problems should disappear.
ciao
jachym
> Hallo,
> which I do trough
> psql=> \d det
> cat | integer |
> cislo | integer |
> kvalita | integer |
> ku_kod | integer |
> Vytvá?ím topologii ...
> Feature: 0
> Topologie byla vytvo?ena.
> Po?et uzl? : 0
> Po?et primitiv : 0
> Po?et bod? : 0
> Po?et linií : 0
> Po?et hranic : 0
> Po?et centroid? : 0
> Po?et ploch : 0
> Po?et ostrov? : 0
> stromy).
> What to do?
> Thanks
> Jachym
> Jachym Cepicky
> OFFICE:
> LDF MZLU v Brn?
> Zem?d?lská 3
> 613 00 Brno
> grass5 mailing list
> grass5@grass.itc.it
Jachym Cepicky
OFFICE:
LDF MZLU v Brn?
Zem?d?lská 3
613 00 Brno
grass5 mailing list
grass5@grass.itc.it
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
