[GRASS5] v.out.ogr error
Does anyone recognize this error from v.out.ogr? I get a similar error if I try to write directly to PostGIS. In both cases the command runs to ~ 25%, then fails with:
GRASS 6.1.cvs (minnesota_utm):~ > v.out.ogr input=mn_forties@pls type=area dsn=~/Desktop/tmp olayer=forties
Exporting 1314202 areas (may take some time) ...
pg(17391) malloc: *** vm_allocate(size=8421376) failed (error code=3)
pg(17391) malloc: *** error: can't allocate region
pg(17391) malloc: *** set a breakpoint in szone_error to debug
DBMI-Postgres driver error:
Cannot describe table
ERROR: Cannot select attributes for cat = 363284
Kirk
