This is an error that I haven’t seen come across the list. I’m trying to reproject vectors from a latlon nad27 location into a wgs84 utm location. I’m using a 9 July 2005 MAC OSX binary. Any thoughts?
Creating vector file…
pj_transform() failed
cause: failed to load NAD27-83 correction file
Error in pj_do_transform
C. Michael Barton, Professor of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
This is an error that I haven¹t seen come across the list. I¹m trying
location. I¹m using a 9 July 2005 MAC OSX binary. Any thoughts?
Creating vector file...
this has to do with Paul's recent fix to make `g.proj -j` display the
full path name to the nadgrid file. Does the
/Applications/Grass/grass61cvs.app/Contents/Resources/grass-6.1.cvs/etc/nad/conus
file exist? I saw the same problem with r(?).proj when I changed the
string to $GISBASE locally, but it has been working fine for me using
the full path (in linux).
try using cs2cs from the command line with some test points:
nus
____________________
PO Box 872402
USA
nus
Hello Michael, did you do this? I can't reproduce the problem using spearfish. If you can reproduce it using cs2cs it might make things clearer. E.g. does the following work:
