Thanks, Radim, for fixing v.report.
It's a slight nightmare that nobody realized this bug for years...
BTW: Is the submission to below branch correct?
What about "release_30_08_2002_grass5_0_0"?
Is the page
http://grass.itc.it/grasscvstags.html
correct?
To avoid another branch nightmare, can we delete all unused branches?
Then at least I understand where to commit
On Wed, Oct 09, 2002 at 06:02:48PM +0200, grass@intevation.de wrote:
Author: radim
Update of /grassrepository/grass/src.contrib/SCS/vector/v.report/cmd
In directory doto:/tmp/cvs-serv27088Modified Files:
Tag: releasebranch_26_april_2002_5_0_0
Gmakefile do_v_stats.c
Removed Files:
perimeter.c
Log Message:
length calc fixIndex: Gmakefile
RCS file: /grassrepository/grass/src.contrib/SCS/vector/v.report/cmd/Gmakefile,v
retrieving revision 1.4
retrieving revision 1.4.2.1
diff -u -d -r1.4 -r1.4.2.1
--- Gmakefile 15 Apr 2002 13:28:34 -0000 1.4
+++ Gmakefile 9 Oct 2002 16:02:46 -0000 1.4.2.1
@@ -11,7 +11,6 @@
prt_report.o\
do_v_stats.o\
prt_unit.o\
- perimeter.o\
report.o\
stats.o\
sums.oIndex: do_v_stats.c
RCS file: /grassrepository/grass/src.contrib/SCS/vector/v.report/cmd/do_v_stats.c,v
retrieving revision 1.2
retrieving revision 1.2.2.1
diff -u -d -r1.2 -r1.2.2.1
--- do_v_stats.c 22 Jan 2002 04:51:44 -0000 1.2
+++ do_v_stats.c 9 Oct 2002 16:02:46 -0000 1.2.2.1
@@ -40,13 +40,13 @@
int cnt=0, line, linea, island;
CELL cat_no;
int first, tot_cats, n_points;
- register int area_num, line_num, i, ii, jj, kk;
+ register int area_num, line_num, i, ii, jj, kk, p;
char *label_name, null[1];
char aline[80];
char map_name[100], *mapset;
long len, nalloc=1024;
double xcent, ycent, *X, *Y;
- double perim;
+ double length;
double f_area;
double ot_area;
double tot_area;
@@ -245,23 +245,26 @@
sleep(2);
return (-1);
- /* Calculate line length */
+ /* Calculate line length */
n_points = Points->n_points;
X = Points->x;
Y = Points->y;- perim = perimeter(n_points,X,Y);
+ length = 0.0;
+ for ( p = 0; p < Points->n_points - 1; p++ ) {
+ length += G_distance( Points->x[p], Points->y[p], Points->x[p+1], Points->y[p+1]);
else
- perim = 0.0;
+ length = 0.0;
}if (first)
vect[0].num = cat_no;
vect[0].line_cnt = 1;
- vect[0].length = perim;
+ vect[0].length = length;
i = 0;
cnt = 1;
first = 0;
@@ -273,7 +276,7 @@
if (vect[i].num == cat_no)
vect[i].line_cnt = vect[i].line_cnt + 1;
- vect[i].length = vect[i].length + perim;
+ vect[i].length = vect[i].length + length;
break;
@@ -282,7 +285,7 @@
cnt++;
vect[i].num = cat_no;
vect[i].line_cnt = 1;
- vect[i].length = perim;
+ vect[i].length = length;
qsort (vect, cnt, sizeof (struct Line_List), cmp);
if (cnt == nalloc)
{--- perimeter.c DELETED ---
grass-commit mailing list
grass-commit@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass-commit
