[GRASS5] v.spag loop and threshold
Hi vector users,
A) v.spag sometimes get stuck in a loop in which it creates the same line over
     and over again (known bug). I found one reason in linecros.c find_intersection ():
  d = D;
  if (fabs (d) > EPSILON) { [...] } [...]
  /* segments are colinear. check for overlap */ [...]
  if (ax1 == ax2 && bx1==bx2 && ax1==bx1) { [...] }else{
        if (ax1 > ax2) { t=ax1; ax1=ax2; ax2=t; }
        if (bx1 > bx2) { t=bx1; bx1=bx2; bx2=t; }
        if (ax1 > bx2) return 0;
        if (ax2 < bx1) return 0;
        if (ax1 == bx2) { *x = ax1; *y = ay1; return 1; }
        if (ax2 == bx1) { *x = ax2; *y = ay2; return 1; }
A1) if ax1 > ax2 then t=ax1; ax1=ax2; ax2=t; and for example *x = ax1( = original ax2!!!); *y = ay1;
       which is not the intersection
A2) if ax1 == ax2 == bx1 < bx2 (because EPSILON = 1.0e-10 and vectors may not be colinear)
       and ay1 == by1 then *x = ax2; *y = ay2; which is not the intersection
My suggestion is:
        if ( (bx1 > ax1) && (bx2 > ax1) && (bx1 > ax2) && (bx2 > ax2) ) return 0;
        if ( (bx1 < ax1) && (bx2 < ax1) && (bx1 < ax2) && (bx2 < ax2) ) return 0;
        if ( (ax1 == bx1 && ay1 == by1) || (ax1 == bx2 && ay1 == by2) )
        if ( (ax2 == bx1 && ay2 == by1) || (ax2 == bx2 && ay2 == by2) )
This change helped on my v.spag loop.
B) Snaping is never used because in main2.c :
static int snap_ok = 0 ;
    if (snap_ok == 1) {
        if (s_val->answer != NULL)
            snap_val = atof(s_val->answer);
        thresh_flag = 0;
    } else { snap_val = 0.0; thresh_flag = 0; }
My suggestion is add options
-s Snap nodes
-p Prompt user for threshold value.
and change code for these options and threshold in the same way as used in v.build.
What others think about it? I'm not sure and don't want cause problems.
Radim
subject 'unsubscribe grass5'
