to provide a high resolution vector coastline dataset I have
converted the
G S H H S
Global Self-consistant Hierarchical High-resolution Shorelines
from Paul Wessel and Walter. H. F. Smith
(ftp://gmt.soest.hawaii.edu/pub/wessel/gshhs/).
A problem arises from v.support which doesn't run on large files (at all or
or in reasonable time, process is still running here). If you are interested
to test GRASS with a *large* vector file, I have prepared the GMT dataset
for you:
To describe it's resolution:
(From the GMT page:) The file gshhs_h.c (High resolution) is at 0.2 km, I
have converted gshhs_f.c (Full resolution) at 0.?km (no value given). So I
have converted the *full* resolution dataset gshhs_f to GRASS ASCII vector
format for you to download at:
ftp://www.geog.uni-hannover.de/outgoing/gshhs_f_grassascii.tar.gz (58MB)
-rw-r--r-- 1 neteler users 226115131 Dez 8 17:42 dig_ascii.gshhs_f
-rw-r--r-- 1 neteler users 10561544 Dez 8 17:42 dig_att.gshhs_f
-rw-r--r-- 1 neteler users 2166637 Dez 8 17:42 dig_cats.gshhs_f
You can use this lat/long world coastline dataset within "global dataset"
location which you get from here (or you define an empty world lat/long
location):
http://www.geog.uni-hannover.de/grass/data.html
Add the missing directories:
$LOCATION/dig_ascii
$LOCATION/dig_cats
and move the files into their directories (rename to gshhs_f or similar of
course). Then
v.in.ascii in=gshhs_f out=gshhs_f
v.support gshhs_f op=build
However, this takes muuucchhh time... Does anyone see a chance to speed
up the v.support topology build function? Maybe it would be useful to
add progress output (percentage) to v.support.
Regards
subject 'unsubscribe grass5'
Markus Neteler wrote:
converted the
G S H H S
for you:
location):
$LOCATION/dig_ascii
$LOCATION/dig_cats
course). Then
I don't know the details but execution time against file size grows at a
rate that is `more than linear' for large files. So large files, like
vector grids, do build very slowly. I think the answer is segmentation.
Perhaps the technique of `walls' where a triangulation topology is built
from a set of points could be modified to build areas. Then only small
regions are built at a time working out from the segment boundaries.
This needs to load the respective segments into a network in memory to
be efficient. A rework of the build function is desperately needed. This
could be in place for 5.1. Anyone else has had thoughts about this?
David
Regards
Hi Andreas,
On Fri, Dec 08, 2000 at 08:25:59PM +0100, Andreas Lange wrote:
Hallo Markus,
koenntest Du vielleicht das Skript/Programm posten, mit dem Du die Daten
konvertierst?
Ich wuerde mir gerne den D'ld von 58 MB sparen, die GSHHS habe ich hier
auf CDROM.
Sure: I have put the sources of Simon Cox' convert program here:
gshhstograss.tar.gz
It's the program from Simon with a few additions (includes added) to
make it compile.
It reads the gshhs binary data files and outputs ASCII vectors.
Probably we should make a nice GRASS module from gshhstograss (r.in.gshhs)?
For details please refer to
ftp://gmt.soest.hawaii.edu/pub/wessel/gshhs/README
> Hi all,
> converted the
> G S H H S
> for you:
> location):
> Bereich Geographie – Naturwissenschaftliche Fakultät – Leibniz Universität Hannover
> $LOCATION/dig_ascii
> $LOCATION/dig_cats
> course). Then
> Regards
> Markus
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de - A.C.Lange@GMX.net
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
Markus,
Great to hear about a program to import the GMT shoreline files. I have
been using these shorelines for a while now. To get them into GRASS I
use the GMT pscoast program which will dump to a multi-segment file. I
then have to run it through some awk routines to get it into a dig_ascii
format. A program to do this and maintian attributes etc, would be a
nice addition. I have downloaded the program and will give it a try.
I am still looking at NVIZ and the color issue. I am trying the
suggestions from Bill Brown with respect to the GL_NORMALIZE routines,
with interesting results. I will keep you posted.
Bob Covill
Tekmap Consulting
P.O. Box 2016
Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill@tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
