Markus,
Happy to try to clarify now I that I've figured out why I've been confused. When you use v.transform from the tcltk menu system, it says to input an ascii vector map. If you click the browse button (labeled "vector_ascii", as is the output map name browse button), it goes to the dig_ascii to search for a map. If you select a map from there it appears in the dialog window. However, when you try to run v.transform (clicking the "run" button) it says file not found.
The problem seems to be that the tcltk menu system has not been updated to reflect changes in v.transform. In the manual, it says binary vector file and v.transform from the command line works as specified there.
Michael
On Thursday, January 29, 2004, at 07:47 AM, grass5-request@grass.itc.it wrote:
Date: Thu Jan 29, 2004 6:01:36 AM America/Phoenix
To: grass5@grass.itc.it
Subject: Re: [GRASS5] Testing Grass 5.3 - v.transformOn Wed, Jan 28, 2004 at 10:20:17PM -0700, Michael Barton wrote:
Radim
Just wanted to let you know. I tested v.transform by typing in the name
of a binary vector file (the browse button looks in the dig_ascii
instead of dig folder). It worked just fine. Thanks for the tip.Michael,
this is not clear to me:
src/mapdev/v.transform/main.c
old->gisprompt = "old,dig,vector";The version in 5.3-CVS refers to the dig file.
Where did you find the reference to dig_ascii? Maybe in 5.0.3?
On Monday, January 19, 2004, at 01:54 AM, Radim Blazek wrote:
On Friday 16 January 2004 17:13, Michael Barton wrote:
As with GRASS 5.7, I've been doing considerable testing of GRASS 5.3.
Overall, it is highly stable and works very well. Here are a couple of
minor items that perhaps could be fixed before it is released as
stable.1. v.transform does not operate correctly, at least under Mac OSX. It
requires an ASCII vector file as input, looks in the dig_ASCII folder,
but will not recognize an ASCII vector file unless it is put (manually
and incorrectly) into the dig folder. It produces an incomplete output
file (header and attributes, but no vectors). This was a problem on an
earlier release; I have tried this on the the 12 January CVS snapshot
and it is still a problem.v.transform was rewritten to read and write vector binary file.
Radim
____________________
______________________________
Michael Barton, Professor & Curator
Department of Anthropology
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
