[GRASS5] v.what and r.what
As mentioned by Michael, I trimmed code from d.what.vect to
create v.what as part of the new gis.m. Right now its output
format is just like the shell script option for d.what.vect.
However when I wrote it it didn't look at r.what before hand
and added input of east and north as separate parameters,
but r.what takes them as a pair. Also the r.what output is
column like separated by vertical bars, where v.what has
each attribute on its on line with the field name and its
value.
I intend to add an option to r.what to provide the same kind
of output as v.what, but since it is desirable to have the
commands similar should I modify v.what to take a coordinate
pair or modify r.what to take coordinate input as two
parameters. Michael prefers the separate parameters and I
prefer it to, but I don't want to break anything, so I'm
asking for advice before I do anything.
Thanks
T
Trevor Wiens
twiens@interbaun.com
On ¶ro, 2006-01-18 at 07:55 -0700, twiens wrote:
<> snip
value.
Could you post an example?
prefer it to,
Why would separate parameters be better?
Best,
Maciek
Szukasz do¶wiadczonej firmy poligraficznej? Zale¿y Ci na terminowo¶ci i atrakcyjnych cenach?
Zapraszamy do nas!
http://www.foldruk.pl/
parameters.
Modify v.what to match r.what. r.what has been around for a while, so
you need to maintain compatibility, whereas v.what is new.
