[GRASS5] v.what and r.what
----- Original Message Follows -----
To: twiens@interbaun.com
Cc: grass5 <grass5@grass.itc.it>
Subject: Re: [GRASS5] v.what and r.what
Date: Thu, 19 Jan 2006 09:57:36 +0100
On ¶ro, 2006-01-18 at 07:55 -0700, twiens wrote:
<> snip
> Also the r.what output is
> column like separated by vertical bars, where v.what has
> each attribute on its on line with the field name and
> its value.
Could you post an example?
Sorry I don't have anything easily availale (away from my
home computer right now). You have r.what on your system
right now. For understanding v.what, run d.what.vect with
the -t option for terse.
> I intend to add an option to r.what to provide the same
> kind of output as v.what, but since it is desirable to
> have the commands similar should I modify v.what to take
> a coordinate pair or modify r.what to take coordinate
> input as two parameters. Michael prefers the separate
> parameters and I prefer it to,
Why would separate parameters be better?
Not better, just a matter of preference. To me it seems
cleaner, but I don't want to change anything that is going
to break things.
T
