[GRASS5] VASKLIB problem
Anyone had any problem with modules using VASKLIB?
My r.le.setup program worked fine under GRASS4.3.
Now after the V_ code, when the user has hit esc-return,
the screen freezes with the cursor in the upper-left corner.
The return values from the V_ code do get passed along
OK to subsequent code, but nothing happens because of
the screen freeze.
Could be a problem in my own code after the V_ section,
but I can't isolate the problem there.
In the old 4.3 version, the Gmakefile used VASK, but I
have fixed that up to just use VASKLIB as in the updated
Gmakefiles in beta 11.
Any ideas?
Bill Baker
subject 'unsubscribe grass5'
Hi Bill,
the screen freeze.
this was a problem in grass5 in past. We fixed it by using
  fprintf(stderr, ""); or
  fprintf(stdout, "");
instead of
  printf();
As described in SUBMITTING, the printf() shouldn't be used. Probably
this helps here if there are printf() in your code?
Kind regards
Markus Neteler
Thanks for the idea, Markus, but I had already fixed the
printf's. Still looking for other problems...
Bill B.
Markus Neteler wrote:
Hi Bill,
> the screen freeze.
instead of
  printf();
Kind regards
Markus Neteler
Hello,
Still struggling with the VASKLIB problem. I have now
isolated the problem. It is in my code that uses the
VASKLIB. If I manually enter values into the array
that is filled by the VASKLIB code, instead of letting
the VASKLIB code do it, the program runs fine.
It appears that the VASKLIB code does not let go of
control of the screen once it is done, as subsequent
attempts by later code to write to the screen fail.
The cursor is hung in the upper left corner after this
VASKLIB code is done.
I wonder if there is someone familiar with the VASKLIB
who could look at my code (attached) to see if there
is anything obvious wrong? The code is pretty short.
I am not an expert programmer, so someone with more
experience might be able to see the problem easily!
Bill Baker
Univ. of Wyoming
Hi Bill,
> the screen freeze.
instead of
  printf();
Kind regards
Markus Neteler
(attachments)
problem.txt (1.61 KB)
