Hi folks:
I've tried to use the function Vect_get_point_in_poly to develop a module
in a linux machine and obtained the next messages:
/scsi2/grass5.0.0pre1/src/CMD
head.i686-pc-linux-gnu
SRC = /scsi2/grass5.0.0pre1/src
CMD = /scsi2/grass5.0.0pre1/src/CMD
UNUSED =
HEADER = head.i686-pc-linux-gnu
ARCH = i686-pc-linux-gnu
GISBASE = /scsi2/grass5.0.0pre1/dist.i686-pc-linux-gnu
VERSION = 5.0.0pre1 May 2001
/scsi2/grass5.0.0pre1/src.paco/mapdev/v.in.bna
make -f OBJ.i686-pc-linux-gnu/make.rules
gcc -s -o
/scsi2/grass5.0.0pre1/dist.i686-pc-linux-gnu/etc/bin/cmd/v.in.bna
OBJ.i686-p
-linux-gnu/main.o
/scsi2/grass5.0.0pre1/src/libes/LIB.i686-pc-linux-gnu/libvect.a /scs
2/grass5.0.0pre1/src/libes/LIB.i686-pc-linux-gnu/libdig2.a
es/LIB.i686-pc-linux-gnu/libgis.a
libdisplay.a
/scsi2/grass5.0.0pre1/src/libes/LIB.i686-pc-linux-gnu/libraster.a /scsi2/g
ass5.0.0pre1/src/libes/LIB.i686-pc-linux-gnu/libcoorcnv.a -lm
-I/usr/include -L/usr/l
b -lz
/scsi2/grass5.0.0pre1/src/libes/LIB.i686-pc-linux-gnu/libvect.a(poly.o):
In function `V
ct_get_point_in_poly':
/scsi2/grass5.0.0pre1/src/libes/vect32/Vlib/poly.c:182: undefined
reference to `link_ext_on_error'
/scsi2/grass5.0.0pre1/src/libes/vect32/Vlib/poly.c:183: undefined
reference to `link_int'
/scsi2/grass5.0.0pre1/src/libes/vect32/Vlib/poly.c:187: undefined
reference to `link_new'
/scsi2/grass5.0.0pre1/src/libes/vect32/Vlib/poly.c:188: undefined
In function `Vect__divide_and_conquer':
/scsi2/grass5.0.0pre1/src/libes/vect32/Vlib/poly.c:240: undefined
In function `destroy_links':
/scsi2/grass5.0.0pre1/src/libes/vect32/Vlib/poly.c:277: undefined
reference to `link_dispose'
collect2: ld returned 1 exit status
make: ***
[/scsi2/grass5.0.0pre1/dist.i686-pc-linux-gnu/etc/bin/cmd/v.in.bna] Error
1
I've found the unrecognized functions in the source
files in .../src/libes/linkm/ directory but have no idea about how make
them easy to find from my program.
Probably it's because my inexpertise in GRASS programming, sorry about
that, but has anybody some idea on how to fix it.
Thanks in advance
Paco.
= Francisco Alonso Sarria =
= Departamento de Geografia =
= Universidad de Murcia =
= E-30001 Murcia SPAIN =
= Telfno: +34 968 364357 =
= e-mail: alonsarp@fcu.um.es =
Hi Francisco,
On Mon, Jul 30, 2001 at 12:56:12PM +0200, Francisco Alonso Sarria wrote:
Hi folks:
UNUSED =
gcc -s -o
OBJ.i686-p
-linux-gnu/main.o
libdisplay.a
b -lz
In function `V
make: ***
1
you have to add $(LINKMLIB) to the LIBES line.
The references are stored in:
src/CMD/generic/make.mid
In your case:
LINKMLIB = $(LIBDIR)/liblinkm.a
So with $(LINKMLIB) it may compile.
Hope this helps,
