On Tue, Aug 09, 2005 at 01:35:48AM -0500, Huidae Cho wrote:
I added 'int R_line_width(int width)' to the raster library. This
changes line width for Draw_line().
Huidae Cho
Hi Huidae,
this is ABSOLUTELY GREAT! I think we discussed it for years...
To all: find attached a small screenshot of d.vect using the
line width feature for the roads map.
Congratulations,
(attachments)
Hi Huidae,
I have just tried the new line width option and it works great.
Unfortunately I think I have discovered a side-effect from it. If you draw another line feature after drawing a vector with the width option it is drawn at whatever width the vector was drawn at. For example if you draw a vector with width=3 and then draw a grid and barscale (for example) the grid and barscale are drawn with the same heavy line.
Is it possible to reset the line width at the end of a draw to avoid this problem?
Bob Covill
Huidae Cho
Hi Huidae,
Congratulations,
Hmm, it seems that R_color() has the same problem if it's not called by
the next drawing module. When I commented out R_color() block (lines
139-143) in display/d.grid/main.c, it draws grid lines with the last
color d.vect used.
In terms of consistency, current R_line_width() looks OK. But since it's
new feature, no drawing module takes into account this side effect or
some modules even don't need this feature. For the latter case, it will
be simple to modify d.vect. Check out the latest CVS version.
Thank you.
Huidae Cho
On Tue, Aug 09, 2005 at 10:05:07AM -0300, Bob Covill wrote:
Hi Huidae,
this problem?
Bob Covill
>>Hi,
>>Huidae Cho
>Hi Huidae,
>Congratulations,
> Markus
I'll second Markus. How do we add it to d.vect?
Michael
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Date: Tue, 9 Aug 2005 11:00:37 +0200
To: Huidae Cho <grass4u@gmail.com>
Cc: <grass5@grass.itc.it>
Subject: [GRASS5] vector line thickness implemented - was Re: R_line_width()
Huidae Cho
Hi Huidae,
Congratulations,
Michael,
it *is* already in d.vect
That's how I made the screenshot. Ready to test.
Michael
USA
> From: Markus Neteler <neteler@itc.it>
>> Hi,
>> Huidae Cho
> Hi Huidae,
> Congratulations,
> Markus
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
Markus,
What is the command for line width. I looked in the on-line manual for GRASS
6.1 and couldn't find it. Maybe added too recently to show up? I'm happy to
add it to the GIS Manager for vector display. Also is it an integer or can
it take a decimal?
Michael
On 8/9/05 12:46 PM, "Markus Neteler" <neteler@itc.it> wrote:
Michael,
Michael
USA
Huidae Cho
Hi Huidae,
Congratulations,
Hi Michael,
The feature has been added to d.vect. Check out the latest CVS version
and you will find 'width=' option in d.vect help. It takes only integer
values since the value is the number of pixels itself on the monitor.
Enjoy
Huidae Cho
On Tue, Aug 09, 2005 at 08:22:50PM -0700, Michael Barton wrote:
Markus,
it take a decimal?
Michael
> Michael,
> Markus
>> Michael
>> USA
>>>> Hi,
>>>> Huidae Cho
>>> Hi Huidae,
>>> Congratulations,
>>> Markus
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Thanks Huidae,
This is an enormous improvement and will make a lot of people happy. I'm in
the midst of an office/lab reorganization at the moment, but as soon as it's
done (hopefully tomorrow) I'll add this to the GIS Manager, probably as an
integer spinner.
Michael
On 8/9/05 8:35 PM, "Huidae Cho" <grass4u@gmail.com> wrote:
Hi Michael,
Enjoy
Huidae Cho
Markus,
it take a decimal?
Michael
Michael,
Michael
USA
R_line_width()
Huidae Cho
Hi Huidae,
Congratulations,
grass5 mailing list
grass5@grass.itc.it
color d.vect used.
Exactly. Almost every module which uses drawing primitives which
depend upon the current colour (everything except for raster drawing
primitives) sets the current colour explicitly.
