[GRASS5] vector maps: use .tmp directory, then final directory
can we change the vector library to first write into
the .tmp directory (as done for raster data) and then
copy into the target directory within vector/?
Like this we also had the "transactional" file management.
Currently, if a vector command fails (crash, connection to
remote machine fails, disk full or other problems), it leaves
corrupted files which appear to be a valid vector map.
On 7/28/05, Markus Neteler <neteler@itc.it> wrote:
Certainly not for update - Vect_open_update().
For new vectors, it would be possible if a table is not created.
If a table is created before/with geometry, we must store
somewhere the information that the table exists, so that it can
be deleted with the vector map.
If a vector map is corrupted, it is reported by library
(size of coor file).
Radim
