[GRASS5] Video tutorials
Hi folks,
i think it will be a good idea to provide some video (swf)
tutorials about the usage of GRASS. :slight_smile:
The learning curve of newbie's will be much higher.
I will make a start!
I created a small tutorial with vnc2swf http://www.unixuser.org/~euske/vnc2swf/
about the usage of r.out.vtk and Paraview:
http://www-pool.math.tu-berlin.de/~soeren/grass/modules/r.out.vtk-tutorial.html
And i will create some more (about the modules i programmed ...).
To create a tutorial is quite easy, all you need is vnc and vnc2swf .
Best regards
Soeren
Hi Sören,
It’s a great idea!
My suggestion is:
  • make videos on 800x600 resolution. This make easier for fitting the video
    on a normal web browser window (using 1024x768 and without needing to
    switch to full screen (browser)).
Christian dos Santos Ferreira
Oceanographer. Msc.
Lab. of Fisheries Research and Hydroacustics
Federal University of Rio Grande (FURG)
Rio Grande - RS - Brazil
Tel +55 (53) 32336528
Website: http://poseidon.furg.br
2006/2/20, Sören Gebbert <soerengebbert@gmx.de>:
Hi folks,
Hi Sören,
I would rather have a mpeg, avi, divx or other "real" video format
than flash, since it is proprietary and doesn't work quite well under
unixen OS.
As Markus is making a strong case for free geodata, this approach
should be coherent with our outspoken ideas and ideals.
Other than that, great idea!
Paulo Marcondes = PU1/PU2PIX
-22.915 -42.229 = GG87vc (http://www.amsat.org/cgi-bin/gridconv)
Debian GNU/Linux = http://rj.debianbrasil.org = http://www.debian.org
> Hi folks,
Hi Sören,
unixen OS.
Well, thats not a big problem, vnc2swf and the support tools can create other output too:
Type Extension Description
shape .swf SWF movie (default)
video SWF movie with stream video encoding
mpeg .mpg MPEG movie (requires PyMedia)
bmp .bmp BMP image sequence
png .png PNG image sequence
With mencoder or transcode you can convert the mpeg-stream/png-images
in every format you want (which is supported). :wink:
btw.: flash is realy small!
Thanks. :slight_smile:
Best regards
Soeren
On Monday 20 February 2006 20:37, you wrote:
Hi Sören,
It's a great idea!
My suggestion is:
- make videos on 800x600 resolution. This make easier for fitting the video
I will try it, but with Paraview it will be hard ...
But i can downscale the movie with edit.py. :slight_smile:
Soeren
Oceanographer. Msc.
