On Wed, May 25, 2005 15:00, Moritz Lennert said:
On Wed, May 25, 2005 14:32, Markus Neteler said:
On Wed, May 25, 2005 at 10:38:29AM +0200, Moritz Lennert wrote:
Hello,
Another missing feature in GRASS is the capacity to easily view the map
attribute table. The current option is 'db.select TableName', but the
output
is not very beautiful and is difficult to browse.
I think this feature would be useful in connection with the other
attribute
management modules I just sent.
Does anyone have an idea how to create a nicer and browsable display of an
attribute table in the tcltk interface ? I guess the easiest would be to
pipe
the db.select results into awk for formatting and then open a new tcltk
window
which displays the results.
Maybe pipe the output of
v.db.select map
into a tcl table viewer?
Yes, this is what I think as well. Daniel suggested TkTable, but I'm looking
at the possibilities of doing this with just the basic tcltk to avoid
creating
another dependency.
Using the code at the bottom of http://wiki.tcl.tk/3150 which uses the 'grid'
widget, I can currently display data relatively nicely, but the frame has the
size of the table, without any scrollbars and so when you get more than just a
few rows it goes way beyond the screen. In addition it takes quite a while to
load the data, so I guess it must be quite inefficient.
But I still have to refamiliarise myself with tcltk in order to create
anything useful. It's been a long time...
Any pointers concerning above problems are more than welcome.
Moritz
I have just added a WHERE statement to v.db.select.
Except for the the fact that in one you chose a map and in the other a
table,
what is the difference between v.db.select and db.select ? (or is
v.db.select
just a sort of frontend to db.select ?)
Moritz
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
