Hi Andy
andy agena wrote:
I should add that the 'vt100' error is when I 'grass5' in an Aqua
terminal. If I'm in a xwindows terminal via vncviewer, the error is
that it can't open 'xterm.'
Jeshua's binaries installed, but I get the following when starting
GRASS:
Starting GRASS ..
Error opening terminal: vt100.
Invalid resource file, removing /var/root/.grassrc5
I don't think I can help much, but looking at the code, my guess is that
the UNIX function initscr() (called within the vask library) is finding
an error. This function exits the program if there is an error after
printing a message (the "Error opening terminal:" message seems to be a
UNIX message not a Grass message). I'm not sure, but it appears that you
have a system problem as opposed to a grass problem. Anyone know more
about the initscr() call and how it works with the vask library?
Sorry I couldn't be of much help.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
subject 'unsubscribe grass5'
Justin,
I get that same message using Cygwin. I checked the
/usr/lib/terminfo and all is well there. I'll look at the
initscr
John Huddleston
----- Original Message -----
To: <grass5@geog.uni-hannover.de>
Sent: Monday, February 19, 2001 12:34 AM
Subject: Re: [GRASS5] vt100 error with osx + xterm error
Hi Andy
> GRASS:
> Starting GRASS ..
Sincerely,
Bangkok, Thailand
to:
Well, I fixed the error for Cygwin. It turned out that the
/usr/lib/terminfo directory was a symbolic link to the
./share/terminfo directory. I removed the symbolic
link, moved the share terminfo directory to /usr/lib and
created a symbolic link from share to ../lib for the
terminfo directory. No more error message. That's
a weird one. It might be because I am using the X-win32
server from StarNET. Programs compiled outside of
Cygwin do not recognize the Cygwin symbolic links. The
xfree binary should work OK.
John Huddleston
Hi Andy
> GRASS:
> Starting GRASS ..
Sincerely,
Bangkok, Thailand
to:
