[GRASS5] web site error for ps.map.html
On the ibiblio, Australian, and UK mirrors (and probably more), the
ps.map HTML man page is broken.
It works on the itc.it and baylor.edu sites.
This is the error:
http://grass.ibiblio.org/gdp/html_grass5/html/ps.map.html
Menu for /grass/gdp/html_grass5/html/ps.map.html
          HTML
[an internal server error occured]
But,
ftp://www.ibiblio.org/pub/packages/gis/grass/gdp/html_grass5/html/ps.map.html
works.
Are the secondary sites mirroring off ibiblio, which may be the root of
the problem?
also broken on first glance:
p.map.html
p.map.new.html
Hamish
At time the entire mirroring system is
partially down. I am waiting for several admins to
change from grass.itc.it to another rsync server,
but it seems to take some time.
However, the reported problem may be different.
This is the error:
          HTML
But,
works.
the problem?
p.map.html
p.map.new.html
Hamish
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler <neteler@itc.it> http://mpa.itc.it
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
