Found another set of problems with the ibiblio GRASS mirror,
links from:
http://grass.ibiblio.org/download.html
to:
http://grass.ibiblio.org/grass5/source/
http://grass.ibiblio.org/grass5/source/snapshot_experimental/
etc.
Forbidden
You don't have permission to access /grass5/source/snapshot_experimental/ on this server.
Apache/1.3.27 Server at grass.ibiblio.org Port 80
versus the same at grass.itc.it:
Index of /grass5/source/snapshot_experimental
Name Last modified Size Description
[DIR] Parent Directory 09-May-2003 17:26 -
[TXT] COPYRIGHT.html 30-Oct-2002 12:15 16k
[TXT] WARNING.html 30-Oct-2002 12:15 4k
[TXT] compiling.html 30-Oct-2002 12:15 3k
[ ] grass50src_cvs_snaps..> 28-Jun-2003 05:47 18.7M
GRASS GIS 5.0 CVS experimental tree (HEAD) snapshot
This directory contains the weekly generated CVS snapshot of the experimental tree (HEAD).
What's that?
If you are not interested to use the CVS program for directly accessing the latest GRASS 5.0 source code, you can follow ongoing development by download a source code from here. This CVS snapshot is the source code checked out from CVS experimental tree (HEAD) repository once a week.
have fun..
Hamish
