On Tue, Nov 20, 2001 at 08:36:49PM -0800, Eric G. Miller wrote:
On Tue, 20 Nov 2001 19:44:50 -0800
"Eric G. Miller" <egm2@jps.net> wrote:
> So, I was looking at fixing that d.area dig_list problem, when I found
> the current sources don't compile. Amongst the rubble was the redefinition
> of all the defined colors in colors.h and vect/dig_defines.h -- and the
> definitions don't match! How this could be the case for so long and
> not cause an error, I don't know. But, the GRASS standard color defines
> should only live in one place. I'm voting to drop the definitions in
> dig_defines and have it include colors.h. But, I don't yet know the
> ramifications of doing so...
As follow-up, I made a few modifications to colors.h and vect/dig_defines.h
and so far it looks okay. I'm updating my CVS and will do a rebuild followed
by some other checks. At least v.digit seemed to get color numbers by
string name, so it seems okay...
I have searched the source code for more local color definitions:
#define MY_COLOR_LIST
"red,orange,yellow,green,blue,indigo,white,black,brown,magenta,aqua,gray,grey,fromcell"
293716 12 -rw-r--r-- 1 neteler ssi 10177 Nov 13 14:17
./src/display/d.rast.num/number.c
opt2->options =
"white,red,orange,yellow,green,blue,indigo,violet,magenta,brown,gray,black";
33676 4 -rw-rw-r-- 1 neteler ssi 2737 Aug 24 15:28
./src/display/d.vect.cats/main.c
#define D_COLOR_LIST
"red,orange,yellow,green,blue,indigo,white,black,brown,magenta,aqua,gray,grey"
131084 12 -rw-r--r-- 1 neteler ssi 9856 Oct 19 14:55
./src/display/d.vect.labels/main.c
fprintf(stderr," orange grey magenta aqua indigo violet brown\n\n");
32785 4 -rw-rw-r-- 1 neteler ssi 3147 Jul 7 2000
./src/mapdev/v.area/where_am_i.c
"orange", "gray", "brown", "magenta", "white", "indigo", "NULL"};
y_color_opt->options =
"white,red,orange,yellow,green,blue,indigo,magenta,violet,brown,gray,black";
t_color_opt->options =
358518 20 -rw-rw-r-- 1 neteler ssi 18362 Jun 18 11:20
./src.contrib/PURDUE/d.linegraph/cmd/linegraph.c
plot->description =
"Colors:red,orange,yellow,green,blue,indigo,violet,magenta,brown,gray,white,black;Icon:diamond,
box, plus, x; Size: 1-9. ";
244596 8 -rw-rw-r-- 1 neteler ssi 4749 Aug 6 16:08
./src.garden/grass.postgresql/d.site.pg/main.c
At least these are suspicious. For parameters the function
D_color_list();
should be fine instead of harcoding the colors.
Due to the conference I cannot change that, anyone else volunteering?
Thanks in advance,
