r3.to.rast slices a volume into rasters based on the vertical resolution
value.
Michael
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Date: Thu, 15 Dec 2005 14:56:32 -0500
To: Michael Barton <michael.barton@asu.edu>
Cc: Sören Gebbert <soerengebbert@gmx.de>, Helena Mitasova
<hmitaso@unity.ncsu.edu>, <grass5@grass.itc.it>
Subject: Re: [GRASS5] Why is r.to.rast3 missing?
It should be r3.to.xxx ; I'd say r3.to.rast; are there many more ways
to
convert r3 to r besides cross-sections?
Daniel.
On 12/15/05, Michael Barton
<michael.barton@asu.edu> wrote:
Can r3.cross.rast get into the CVS too? This
is a great tool.
I'm name neutral about this as long as I get it right and
put it in the menu
correctly.
However, if I wanted to get philosophical,
I'd say that you should name the
module with respect to the file type you
start with for type conversion
within grass. Things starting with raster and
converting to something else
should be r.to.xxx. Things starting with rast3
should be r3.to.xxx.
Currently we have r.to.vect and v.to rast for
example.
Michael
Michael Barton,
USA
voice:
www:
> From: Sören Gebbert
> Date: Thu, 15 Dec 2005 16:58:51 +0100 (MET)
> To:
Helena Mitasova <hmitaso@unity.ncsu.edu>
> Cc: <michael.barton@asu.edu>,
> Maybe we should rename r3.in.rast to r.to.rast3 and move it into
the
> grass6/raster directoy,
> to prevent name confusions?
btw.:
> there is also a module called r3.cross.rast, which produces cross
section
> raster maps from 3d maps,
> at my homepage. Should i rename it
to r.cross.rast3?
> my homepage:
http://www-pool.math.tu-berlin.de/~soeren/grass/modules/
> Soeren
>> Michael Barton wrote:
>>> Any reason why r.to.rast3 is missing from the
normal GRASS distribution?
>> it is there - it is called r3.in.rast. I
always forget the name too and
>> look for it.
>> Helena
> Lust, ein paar Euro nebenbei zu verdienen? Ohne Kosten, ohne Risiko!
> Satte Provisionen f�r GMX Partner: GMX Produkte Übersicht: Apps, Browser, MailCheck und Co.
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Daniel Calvelo Aros
