[GRASS5] Win32 configure.
Hi all.
One of the problems with building on Windows is that the configure script
doesn't work well.
Q 1.
By inspecting configure.in, I notice that a check should be done for rpclib
in the XDR part as follows:
XDRLIB=
if test -z "${XDRLIB}"; then
AC_CHECK_LIB(sun, xdr_int, XDRLIB=-lsun)
fi
AC_CHECK_LIB(nsl, xdr_int, XDRLIB=-lnsl)
fi
AC_CHECK_LIB(rpclib, xdr_int, XDRLIB=-lrpclib)
fi
AC_SUBST(XDRLIB)
As I haven't been able to get autoconf to work on my computer, could someone
please do this and check it in?
Q 2.
Also, I happen to keep my X headers and libraries in /usr/local/X11r6.4
which doesn't get picked up by configure. Maybe what I really need to do is
move them elsewhere rather than expecting configure to do this.
Is there a recommended location to put them on Windows?
Mike Thomas.
subject 'unsubscribe grass5'
Hi Mike,
i'll check in the XDR part.
Will this suffice? I had the problem that the sunrpc packet is installed
under /usr/local/{include|lib} instead of /usr/{include|lib}.
For the headers: I think that you should leave the headers and libraries
as installed and edit manually the src/CMD/head/head.* file unless this
is implemented correctly with configure.
cu,
Andreas
Mike Thomas wrote:
Hi all.
doesn't work well.
Q 1.
XDRLIB=
fi
fi
fi
AC_SUBST(XDRLIB)
Q 2.
Mike Thomas.
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de - A.C.Lange@GMX.net
Hi Andreas.
Thanks and yes, I just installed it in /usr/{include|lib} to stop that
problem. It would be nice to get configure to look in
/usr/local/{include|lib} as well though/
I'm trying to avoid having to do it by hand all the time, it's what
configure should be doing rather than me - just call me lazy!
Mike Thomas.
Hi Mike,
Thats what configure is for. But with grass it is complicate to
implement this.
We are working to get configure up'n'running. But there are a lot of
problems to figure out on Win32. See my other mails.
If you expirience other problems (or find solutions on Win32!), please
mail again to the list.
cu,
Andreas
