I downloaded the new binary version from http://geni.ath.cx/grass.html
(thanks Huidae Cho) which had the .dll libraries in the lib folder. In
fact it had a link to ***.5.7.cvs.dll files (e.g to
libgrass_gis.5.7.cvs.dll)
But again for some reason I had the same problem as before. It could not
find the libgrass_gis.dll file. I decided to rename all the
*.5.7.cvs.dll files to *.dll and it seems to work fine now.
Huidae can you provide a better solution for this problem?
Sotiris
-----Original Message-----
From: wingrass-admin@grass.itc.it [mailto:wingrass-admin@grass.itc.it]
On Behalf Of Huidae Cho
Sent: Saturday, December 11, 2004 10:12 AM
To: wingrass@grass.itc.it
Subject: [winGRASS] winGRASS 5.7 updated
I know that some people are experiencing a problem with running grass
that I'm distributing. Please make sure that you installed tcl/tk from
my
site. Cygwin version of tcl/tk doesn't work for grass.
Find the latest version at http://geni.ath.cx/grass.html
Thanks.
Huidae Cho
winGRASS mailing list
winGRASS@grass.itc.it
http://grass.itc.it/mailman/listinfo/wingrass
Could you explain how you got the error?
Which interface are you using?
1. commandline
2. d.m
3. tcltkgrass
Which command did you run and got the error?
1. ps.map
2. everything doesn't work
Please check your library dependency of whatever command you run:
cygcheck /usr/local/grass.../bin/ps.map
Then it should print libraries that it requires. Try this in and outside
grass.
Thanks.
Huidae Cho
Sotiris
my
Thanks.
Huidae Cho
