Per Justin Hickey's suggestion, I'm sending these changes to the list.
The listing that follows provides a partial path name to each of the files
I changed offset by lines of "%", a brief description of the changes, and
the full listing of the file that contains the changes.
Roger Miller
grass5.0beta10/src/libes/gis/mapset_msc.c
I added a version of G__mapset_permissions that uses the access library
function to determine permissions on a mapset. The new code is used when
RELAXED PERMISSION is defined, otherwise the old code is used. In this
case RELAXED_PERMISSION is hardwired set
#define RELAXED_PERMISSION 1
* G__make_mapset_element (element)
* char *element element to be created in mapset
* make the specified element in the current mapset
* will check for the existence of the element and
* do nothing if it is found so this routine
* can be called even if the element already exists
#include <string.h>
#include <unistd.h>
#include <stdlib.h>
#include "gis.h"
#include <sys/types.h>
#include <sys/stat.h>
int G__make_mapset_element (char *p_element)
char command[1024];
char *path;
char *p;
char *G_mapset();
char *element;
element = p_element;
if (*element == 0)
return 0;
strcpy (path = command, "mkdir ");
while (*path)
path++;
G__file_name (p = path, "", "", G_mapset());
while (*p)
p++;
/* add trailing slash if missing */
--p;
if (*p++ != '/')
*p++ = '/' ;
*p = 0;
/* now append element, one directory at a time, to path */
while (1)
if (*element == '/' || *element == 0)
*p = 0;
/* MOD shapiro 16apr91 */
if (access (path, 0) != 0)
mkdir(path,0777);
/* end MOD */
system (command);
char err[1024];
sprintf (err, "can't make mapset element %s (%s)", p_element, path);
G_fatal_error (err);
exit(1);
if (*element == 0)
return 1;
*p++ = *element++;
* G__mapset_permissions (mapset)
* returns: 1 mapset exists, and user has permission
* 0 mapset exists, BUT user denied permission
* -1 mapset does not exist
#ifdef RELAXED_PERMISSION
int G__mapset_permissions (char *mapset)
char path[256];
G__file_name (path,"","",mapset);
if(access(path,F_OK) != 0)
return -1;
if(access(path,R_OK|W_OK) !=0)
return 0;
return 1;
#else
char path[256];
struct stat info;
if (stat (path, &info) != 0)
return -1;
if (info.st_uid != getuid())
return 0;
if (info.st_uid != geteuid())
return 0;
return 1;
#endif
grass5.0beta10/src/libes/gis/gisinit.c
Very small change. I added a line to set umask to 002. The original code used 022. RELAXED_PERMISSION is set to use 002, and not set to use 022.
* G_gisinit(pgm)
* char *pgm Name to be associated with current program
* Does some program initialization. Read comments in this file
* for details.
#include <stdio.h>
#include <unistd.h>
#include "gis.h"
#include "G.h"
#include "version.h"
struct G__ G__ ;
static int initialized = 0;
static int gisinit();
CELL CELL_NODATA; /* defined in gis.h */
int G_gisinit( char *pgm)
char *mapset;
char msg[100];
G_set_program_name (pgm);
CELL_NODATA = 0; /* 0 for the moment */
/* Make sure location and mapset are set */
G_location_path();
switch (G__mapset_permissions (mapset = G_mapset()))
case 1:
break;
case 0:
sprintf(msg,"MAPSET %s - permission denied", mapset);
G_fatal_error (msg);
exit(-1);
break;
default:
sprintf(msg,"MAPSET %s not found", mapset);
exit(-1);
break;
gisinit();
return 0;
int G_no_gisinit(void)
gisinit();
return 0;
int G__check_gisinit()
if (initialized) return 1;
fprintf (stderr, "\7ERROR: System not initialized. Programmer forgot to call G_gisinit()\n");
sleep(3);
exit(-1);
int i ;
/* Mark window as not set */
G__.window_set = 0 ;
/* no histograms */
G__.want_histogram = 0;
/* Mark all cell files as closed */
for (i = 0; i < MAXFILES; i++)
G__.fileinfo[i].open_mode = -1;
/* Set compressed data buffer size to zero */
G__.compressed_buf_size = 0;
G__.work_buf_size = 0;
G__.null_buf_size = 0;
G__.mask_buf_size = 0;
/* mask buf we always want to keep allocated */
G__reallocate_mask_buf();
/* set the write type for floating maps */
G__.fp_type = FCELL_TYPE;
G__.fp_nbytes = XDR_FLOAT_NBYTES;
/* Set masking flag unknown */
G__.auto_mask = -1 ;
/* set architecture dependant bit patterns for embeded null vals */
G__init_null_patterns();
initialized = 1;
umask(002);
#else
umask(022);
#endif
return 0;
grass5/etc/Init.sh
I moved the locking step from the beginning of the code to the point after
LOCATION is defined, then modified that part of the script to use $LOCATION
rather than $HOME. It was not necessary to change the "lock.c" code. I also
changed the error message to reflect that change. In the bash setup, I
changed "umask 022" to "umask 002". I don't see that similar changes can be
made for other shells.
# $Id: init.sh,v 1.23 2000/12/07 07:36:24 cho Exp $
# MODULE: Grass Initialization
# AUTHOR(S): Original author unknown - probably CERL
# Huidae Cho - Korea - hdcho@geni.knu.ac.kr
# Justin Hickey - Thailand - jhickey@hpcc.nectec.or.th
# Markus Neteler - Germany - neteler@geog.uni-hannover.de
# PURPOSE: The source file for this shell script is in
# src/general/init/init.sh. It sets up some environment
# variables and the lock file. It also parses any remaining
# command line options for setting the GISDBASE, LOCATION, and/or
# MAPSET. Finally it starts grass with the appropriate user
# interface and cleans up after it is finished.
# COPYRIGHT: (C) 2000 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
: ${GISBASE?}
# Set PATH to GRASS bin, ETC to GRASS etc
ETC=$GISBASE/etc
PATH=$GISBASE/bin:$GISBASE/scripts:$PATH
export PATH
# Set some environment variables if they are not set
if [ ! "$PAGER" ] ; then
PAGER=more
export PAGER
fi
if [ ! "$GRASS_TCLSH" ] ; then
GRASS_TCLSH=tclsh
export GRASS_TCLSH
fi
if [ ! "$GRASS_WISH" ] ; then
GRASS_WISH=wish
export GRASS_WISH
fi
# First time user - GISRC is defined in the grass script
if [ ! -f $GISRC ] ; then
cat $ETC/grass_intro
echo
echo "Hit RETURN to continue"
read ans
# This is a hack for not having a good initial gui - should be removed
# with next version of initialization gui
GRASS_GUI="text"
fi
echo "Starting GRASS ..."
# Check if we are running X windows by checking the DISPLAY variable
if [ "$DISPLAY" ] ; then
# Check if we need to find wish
if [ "$GRASS_GUI" = "tcltk" ] ; then
# Search for a wish program
WISH=
for i in `echo $PATH | sed 's/^:/.
s/::/:.:/g
s/:$/:./
s/ /g'`
do
if [ -f $i/$GRASS_WISH ] ; then
WISH=$GRASS_WISH
break
fi
done
# Check if wish was found
if [ "$WISH" ] ; then
# Set the tcltkgrass base directory
TCLTKGRASSBASE=$GISBASE/tcltkgrass
export TCLTKGRASSBASE
else
# Wish was not found - switch to text interface mode
echo
echo "WARNING: The wish command ($GRASS_WISH) was not found!"
echo "Please check your GRASS_WISH environment variable."
echo "Use the -help option for details."
echo "Switching to text based interface mode."
echo
echo "Hit RETURN to continue."
read ans
GRASS_GUI="text"
fi
fi
else
# Display a message if a graphical interface was expected
if [ "$GRASS_GUI" != "text" ] ; then
# Set the interface mode to text
echo
echo "WARNING: It appears that the X Windows system is not active."
echo "A graphical based user interface is not supported."
echo
read ans
GRASS_GUI="text"
fi
fi
export GRASS_GUI
# Save the user interface variable in the grassrc file - choose a temporary
# file name that should not match another file
if [ -f $GISRC ] ; then
awk '$1 !~ /GRASS_GUI/ {print}' $GISRC > $GISRC.$$
echo "GRASS_GUI: $GRASS_GUI" >> $GISRC.$$
mv -f $GISRC.$$ $GISRC
fi
# Parsing argument to get LOCATION
if [ ! "$1" ] ; then
# Try interactive startup
LOCATION=
else
# Try non-interactive startup
L=
if [ "$1" = "-" ] ; then
if [ "$LOCATION" ] ; then
L=$LOCATION
fi
else
L=$1
if [ `echo $L | cut -c 1` != "/" ] ; then
L=`pwd`/$L
fi
fi
if [ "$L" ] ; then
MAPSET=`basename $L`
L=`dirname $L`
if [ "$L" != "." ] ; then
LOCATION_NAME=`basename $L`
L=`dirname $L`
GISDBASE=$L
fi
fi
fi
if [ "$GISDBASE" -a "$LOCATION_NAME" -a "$MAPSET" ] ; then
LOCATION=$GISDBASE/$LOCATION_NAME/$MAPSET
if [ ! -r $LOCATION/WIND ] ; then
echo "$LOCATION: No such location"
exit
fi
export GISDBASE LOCATION_NAME MAPSET
if [ -s $GISRC ] ; then
sed -e "s|^GISDBASE:.*$|GISDBASE: $GISDBASE|; \
s|^LOCATION_NAME:.*$|LOCATION_NAME: $LOCATION_NAME|; \
s|^MAPSET:.*$|MAPSET: $MAPSET|" $GISRC > $GISRC.$$
if [ $? -eq 0 ] ; then
else
rm -f $GISRC.$$
echo "Failed to create new $GISRC"
LOCATION=
fi
else
echo "GISDBASE: $GISDBASE" > $GISRC
echo "LOCATION_NAME: $LOCATION_NAME" >> $GISRC
echo "MAPSET: $MAPSET" >> $GISRC
fi
else
echo "GISDBASE, LOCATION_NAME and MAPSET variables not set properly."
echo "Interactive startup needed."
exit
fi
fi
# User selects LOCATION and MAPSET if not set
if [ ! "$LOCATION" ] ; then
case "$GRASS_GUI" in
# Check for text interface
text)
$ETC/set_data
case $? in
0) ;;
*) exit ;;
esac
eval `g.gisenv`
# Check for tcltk interface
tcltk)
eval `$WISH -file $TCLTKGRASSBASE/script/gis_set.tcl`
case $? in
1)
# The gis_set.tcl script printed an error message so wait
# for user to read it
echo "Hit RETURN to continue..."
read ans
GRASS_GUI="text"
export GRASS_GUI
fi
$ETC/set_data
case $? in
0) ;;
*) exit ;;
esac
eval `g.gisenv`
0)
# These checks should not be necessary with real init stuff
if [ "$LOCATION_NAME" = "##NONE##" ] ; then
$ETC/set_data
if [ $? != 0 ]; then
echo "GISDBASE: $OLD_DB" > $GISRC
echo "LOCATION_NAME: $OLD_LOC" >> $GISRC
echo "MAPSET: $OLD_MAP" >> $GISRC
exit
fi
eval `g.gisenv`
fi
if [ "$LOCATION_NAME" = "##ERROR##" ] ; then
echo "The selected location is not a valid GRASS location"
exit
fi
echo "Invalid return code from gis_set.tcl."
echo "Please advise GRASS developers of this error."
esac
# Shouldn't need this but you never know
echo "ERROR: Invalid user interface specified."
echo "Use the -help option to grass for valid interfaces."
exit
esac
fi
LOCATION=${GISDBASE?}/${LOCATION_NAME?}/${MAPSET?}
export LOCATION
# Set the GIS_LOCK variable to current process id
lockfile=$LOCATION/.gislock5
GIS_LOCK=$$
export GIS_LOCK
# Check for concurrent use
$ETC/lock $lockfile $$
case $? in
0) ;;
1)
echo $MAPSET is currently in use. Concurrent use is not allowed.
exit ;;
echo Unable to properly access $lockfile
echo Please notify system personel.
exit ;;
esac
trap "" 2 3
sh="`basename $SHELL`"
case "$sh" in
ksh) shellname="Korn Shell";;
csh) shellname="C Shell" ;;
tcsh) shellname="TC Shell" ;;
bash) shellname="Bash Shell" ;;
sh) shellname="Bourne Shell";;
*) shellname=shell;;
esac
# Start the chosen GUI but ignore text
tcltk)
$GISBASE/bin/tcltkgrass &
# Ignore others
esac
# Display the version and license info
clear
echo "Welcome to GRASS 5.0beta10 (December 2000) "
echo
echo "Geographic Resources Analysis Support System (GRASS) is Copyright,"
echo "1999-2000 by the GRASS Development Team, and licensed under terms of the"
echo "GNU General Public License (GPL)."
echo
echo "This GRASS 5.0beta10 release is coordinated and produced by the"
echo "GRASS Development Team headquartered at University of Hannover with"
echo "worldwide support and further development sites located at Baylor"
echo "University and the University of Illinois."
echo
echo "This program is distributed in the hope that it will be useful, but"
echo "WITHOUT ANY WARRANTY; without even the implied warranty of"
echo "MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU"
echo "General Public License for more details."
echo
echo "This version running thru the $shellname ($SHELL)"
echo "Help is available with the command: g.help"
echo "See the licence terms with: g.version"
if [ "$GRASS_GUI" = "text" ] ; then
echo "Start the graphical user interface with: tcltkgrass&"
else
echo "If required, restart the graphical user interface with: tcltkgrass&"
fi
echo "When ready to quit enter: exit"
case "$sh" in
csh|tcsh)
USERHOME=$HOME # save original home
HOME=$LOCATION
export HOME
cshrc=$HOME/.cshrc
tcshrc=$HOME/.tcshrc
rm -f $cshrc $tcshrc
echo "set home = $USERHOME" > $cshrc
echo "set history = 30 noclobber ignoreeof" >> $cshrc
echo "set prompt = '\\" >> $cshrc
echo "Mapset <${MAPSET}> in Location <${LOCATION_NAME}> \\" >> $cshrc
echo "GRASS 5.0beta10 > '" >> $cshrc
echo 'set BOGUS=``;unset BOGUS' >> $cshrc
if [ -r $USERHOME/.grass.cshrc ]
then
cat $USERHOME/..grass.cshrc >> $cshrc
fi
if [ -r $USERHOME/.cshrc ]
then
grep '^ *set *mail *= *' $USERHOME/.cshrc >> $cshrc
fi
if [ -r $USERHOME/.tcshrc ]
then
grep '^ *set *mail *= *' $USERHOME/.tcshrc >> $cshrc
fi
if [ -r $USERHOME/.login ]
then
grep '^ *set *mail *= *' $USERHOME/.login >> $cshrc
fi
echo "set path = ( $PATH ) " | sed 's/ /'g >> $cshrc
cp $cshrc $tcshrc
$ETC/run $SHELL
HOME=$USERHOME
export HOME
bash)
HOME=$LOCATION # save .bashrc in $LOCATION
export HOME
bashrc=$HOME/.bashrc
rm -f $bashrc
echo "test -z $PROFILEREAD && . /etc/profile" > $bashrc
echo "test -e ~/.alias && . ~/.alias" >> $bashrc
# echo "umask 022" >> $bashrc
echo "umask 002" >> $bashrc
echo "PS1='GRASS:\w > '" >> $bashrc
if [ -r $USERHOME/.grass.bashrc ]
then
cat $USERHOME/.grass.bashrc >> $bashrc
fi
echo "export PATH=$PATH" >> $bashrc
echo "export HOME=$USERHOME" >> $bashrc # restore user home path
$ETC/run $SHELL
HOME=$USERHOME
export HOME
PS1="
Mapset <$MAPSET> in Location <$LOCATION_NAME>
GRASS-GRID > "
export PS1
$ETC/run $SHELL
esac
trap 2 3
# Grass session finished
clear
echo "Cleaning up temporary files....."
($ETC/clean_temp > /dev/null &)
rm -f $lockfile
echo "done"
echo
echo
echo
echo "Goodbye from GRASS GIS"
echo
subject 'unsubscribe grass5'
