ok, more or less, this is where we are:
wish list
. r3.flow (almoste done, Jaro Hofierka)
3D flowtracing module
. s.volt.rst (almost done, Jaro Hofierka)
4D interpolation with saviong time series of g3d volumes or 2d
intersection files
. link/conversion to and from 2D data
(merging 2D files to 3D file and splitting 3D file to 2D layers)
. merging "elevation" 2d surface to 3d file
1 = air (?)
0 = surface (?)
-1 = soil (?)
(e.g. geological fault surfaces)
. visualization - NVIZ - support of 3D raster
(integration of sg4d or r3.showdspf functionality?)
(Tomas Paudits has started on this)
(porting sg4d to i686-pc?)
. some sort of user interaction with 3d data on monitor
(something like d.what.rast)
. support of time series (needed also for 2d data), naming
conventions?
. data conversions between 3D vector (Grass5.1) and 3D raster format
. r3.stats
. r3.recode
. r3.what
. r3.out.v5d/r3.in.v5d with support of 5d data, i.e. time series of
3d data merged to v5d animation file
. r3.proj?
. xganim - support of 3d data animation?
. add the possibility to define in the volume "boundaries surfaces"
(support to regionally restricted interpolation/analysis)
[keeping soil horizon boundaries or stratifications]
. hist files
. r3.mapcalc add the capability to use also 2d-raster
. r3.mapcalc add absolute cell reference
. temporal series and 4D data format, compression...
. export to netcdf format
(a 2D version already exist, written by Alessandro Frigeri,
Generic Mapping Tools and Explorer-OpenDX are supported)
g3d libraries
two tipe of functions can be defined:
tiles-functions and no-tile-functions
. now (I hope) all the parameters in the no-tile-functions are called
in the order:
rows, cols, levels
iven if sometimes the notation
y, x, z
is used
. the parameters in the tile-functions are called in the order:
x, y, z
cols, rows, levels
is used
known bugs
. r3.mapcalc crash increasing the number of levels (error in
G3d_getTilePtr)
. r3.mask crash (error in G3d_getTilePtr)
. r3.showdspf some parameters don't work
. r3.out.v5d always/sometimes(?) it reverses t-b, n-s order
discussion
. extend the new r.mapcalc to a third dimension and replace the
current r3.mapcalc
. for loops: levels, rows, cols
(once for all, let's define them)
. do the tile-functions (see above) have to use x,y,z notation or
could/should it be
moved to rows,cols,levs?
. tiles support/use/performance
. update docs, bugs, todo files in src.contrib/GMSL/g3d
Alfonso
