[GRASS5] XDRIVER / Display problem
Markus,
Unfortunately I have not been able to repeat your error as you indicated
but I have been able to partially run down the error I was getting
The problem I was seeing (on RH 6.2 intel)
Error G_malloc: out of memory
Is (was) repeatable with CELL and HTMLMAP and of course XDRIVER
(I suspect that your error will be likewise repeatable)
I traced it to (I stopped before getting to the end)
src/libes/gis/set_window.c
G_set_window ()
The problem is not set_window but some function called by it.
I want to look at some source files from a couple of weeks ago.
I don't have historical files at home, so it will have to wait for
tomorrow.
I will mail you as soon as I find out more.
C.
BTW
g.region rast=...
or some part of the clipping code
aren't working correctly now.
I get random scan rows shifted to the right.
E-Mail: candrsn@mindspring.com
Date: Sun, 01:00:00 +0000 (GMT)
Flying Monkeys Usually Mean Trouble.
subject 'unsubscribe grass5'
