after working in a GRASS session for some more time without
d.erase I realized by resizing the monitor, that some
20 display commands had been accumulated (generally fine!).
My question/suggestion is: If
d.rast map
is used, can't this be used to erase the command list in GRASS
monitor? As d.rast will overwrite everything (am I wrong?) it's
effectively the same as
d.erase
d.rast map
Just a suggestion for redraw convenience,
maybe I oversee something,
On Sat, 12 Jan 2002 22:52:47 +0100, Markus Neteler <neteler@itc.it> wrote:
d.rast map
d.erase
d.rast map
Have you never used d.rast to display more than one adjacent or
overlapping raster? I think the answer to that question will
answer your question
Eric G. Miller <egm2@jps.net>
> Hi,
> d.rast map
> d.erase
> d.rast map
Sorry, Eric,
I was not very precise. Of course I know the difference:
d.rast -o somemap
was *not* meant. I should have written that I only think of
a pure:
d.rast map
If -o is used, the list in monitor should be kept of course.
Am I still missing something?
Hi Markus, Hi Eric,
> Hi,
> d.rast map
> d.erase
> d.rast map
The behaviour of d.rast was as Markus outlined above (calls
D_clear_window if no -o option).
But i believe that this is not consistent, as no other display module
wipes out the display. And i had problems with the window re-creation
and d.save, because the pad structure was erased with this original
setup.
And the manual page says:
If the active graphics frame already contains text or graphics, and the
user does not wish to use the -o option, it is wise to first invoke
d.erase to clear the active graphics frame before running d.rast.
So i think the existing users of GRASS have to learn the new setup, and
the new users will enjoy enhanced consistency. Just remember to run
d.frame -e and/or d.erase to initialize the display.
But if you all disagree, i will revert my changes in
src/display/d.rast/cmd/display.c .
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
url: http://mitglied.tripod.de/AndreasLange
mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
> > d.rast map
> > d.erase
> > d.rast map
setup.
Now that we're on the subject, I'm wondering why -o isn't the default
behaviour. It was understandable before the introduction of null
values, but now -o should probably be the default, possibly with a
separate option to fill null-valued cells.
Also, even without "-o", d.rast doesn't overwrite the entire display.
> > > d.rast map
> > > d.erase
> > > d.rast map
> setup.
In my opinion a good suggestion.
