On Fri, Jan 26, 2001 at 10:55:51AM +0100, Bernhard Reiter wrote:
On Fri, Jan 26, 2001 at 09:07:34AM +0000, Markus Neteler wrote:
> On Thu, Jan 25, 2001 at 07:55:07PM +0100, Radim Blazek wrote:
> John Huddleston has benn uploading the IPC code into XDRIVER
> from Malcolm Blue (unfortunately without announcement).
> >From my experience it works well in Linux, but:
> You have to rebuild most. See the file README.ipc (which is a script
> as well), it should do the job. After compilation it will run o.k.
> Or am I wrong? John, please post the changes!!
If this is causing problem on some platforms, we might be able to
use CVS to revert to a more tested revision of this code for the
release.
(Just to make you again aware of the capabilities of CVS.)
Generally a good advice
But developers are somewhat responsible for
their changes, so they should revert if a bug occurs. As a second
choice other shall take for it (idea of distributed workload).
Concerning XDRIVER:
I checked with cvs2cl.pl
src/display/devices/XDRIVER:
2001-01-23 01:06 john
* lib/connect.c: connect.c changed to run under cygwin
2001-01-23 01:05 john
* XDRIVER24/SWITCHER.c: SWITCHER.c changed to run under cygwin
cd src/libes/
2001-01-23 01:04 john
* raster/io.c: io.c chnaged to run under cygwin
Maybe it was intended to update the files
src/display/devices/XDRIVER/lib/ipc.new/connect.c
src/display/devices/XDRIVER/XDRIVER24/ipc.new/SWITCHER.c
src/libes/raster/ipc.new/io.c
Sorry, due to lack of time I cannot migrate the misplaced update into
the individual ipc.new/ directories and revert the changes in the parent
directories...
subject 'unsubscribe grass5'
