[GRASS5] XDRIVER problem
Radim,
Those messages are printed after checking the fifo files. I haven’t seen or used 3Dx1 before, but this is defined in etc/monitorcap, I presume. I would suggest that you check that the dev/ directory and the entry in etc/monitorcap for 3Dx1 and/or x1 and make sure that the files pointed to in monitorcap exist in the dev directory. Also make sure that the FIFO file is really a FIFO file, it should show up in a long directory listing as prw-rw-rw- .
Malcolm
Radim Blazek wrote:
I have some problems with XDRIVER:
GRASS:~ > d.mon start=3Dx1
using default visual which is TrueColor
Visual is read-only or using a private colormap
ncolors: 32768
allocating memory...
Graphics driver [x1] started
Please start graphics monitor <x1>.
Error - Graphics monitor <x1> not running!
(But monitor window is opened)
GRASS:~ > d.mon select=3Dx1
Error - Graphics monitor <x1> not running!    =
One week old version seems to work well.
I have similar problem on two computers.
The source is fresh from CVS. (Linux RH6, KDE1)
Radim
