[GRASS5] XDRIVER problems
Thanks, Huidae,
for reverting the IPC-changes and migrating them into ipc.new/
please try again to compile and use the XDRIVER.
subject 'unsubscribe grass5'
My fault everyone,
I had put the ipc.new source code into the system. I thought it
had been tested in the Unix platforms. I remember seeing an
email from Markus stating that it was faster.
I'll reiterate what I asked Markus offline. It would be nice
to have a phone conversation with all parties involved.
Email and the day or two delay can only go so far.
Thanks Huidae for reinstating the code. So, now to do a
Cygwin build will I always have to manually copy the ipc.new
code into the directory above it before a build?
John Huddleston
----- Original Message -----
From: "Markus Neteler" <neteler@geog.uni-hannover.de>
To: <grass5@geog.uni-hannover.de>
Sent: Friday, January 26, 2001 9:08 AM
Subject: Re: [GRASS5] XDRIVER problems
Thanks, Huidae,
Hi John and all Cygnus friends,
On Fri, Jan 26, 2001 at 10:32:41AM -0700, John Huddleston wrote:
My fault everyone,
John, I wasn't expecting that you would install into the main
directory but into the ipc.new/ subdirectory unless it was
tested on *all* platforms.
Never mind...
Very true! I still would be glad if the developers could meet
each other!
No, Huidae just implemented two new parameters into "configure":
  --with-ipc use ipc XDriver instead of fifo (for Cygwin)
  --with-fifo use fifo XDriver instead of ipc (default)
Huidae - good idea, thanks!
So it shouldn't bother you any more and the IPC code can be
savely developed in parallel.
Thank you Markus, Huidae, and Malcolm,
From now on I will concentrate on building it.
John Huddleston
Sent: Friday, January 26, 2001 11:23 AM
<snip>
