[GRASS5] XDRIVER problems
I have tested the configure, README.ipc and ipc.new
(SWITCHER.c and io.c) updates on cygwin and these work
well. I will test on Linux as well.
Thanks for the quick response, Huidae.
Malcolm
--- John Huddleston <jhudd@lamar.colostate.edu> wrote:
Thank you Markus, Huidae, and Malcolm,
From now on I will concentrate on building it.
John Huddleston
----- Original Message -----
<neteler@geog.uni-hannover.de>
To: <grass5@geog.uni-hannover.de>
Sent: Friday, January 26, 2001 11:23 AM
Subject: Re: [GRASS5] XDRIVER problems
<snip>
> No, Huidae just implemented two new parameters
into "configure":
> --with-ipc use ipc XDriver instead
of fifo (for Cygwin)
> --with-fifo use fifo XDriver instead
of ipc (default)
> Huidae - good idea, thanks!
> So it shouldn't bother you any more and the IPC
code can be
> savely developed in parallel.
> Markus
If you want to unsubscribe from GRASS Development
Team mailing list write to:
subject 'unsubscribe grass5'
_______________________________________________________
Do You Yahoo!?
Get your free @yahoo.ca address at http://mail.yahoo.ca
