[GRASSLIST:1001] Populating fields of one table based on SQL query from another ta ble
I'm trying to build an SQL query where the DGPS northings and eastings from
a table of ship navigation gets written to a second table of sample
locations only where the two tables have matching timestamps. So I basically
have timestamps for my samples, but no positions. I'm unsure of the correct
sql syntax (using Sqlite):
Here's what the query should do:
"select * from Easting and Northing in Ship_Navigation WHERE Timestamp ==
Timestamp in Station_Samples." | db.execute
Is this type of query possible?
~ Eric.
Yes that is possible. The trick is making sure the two time stamps are
EXACTLY the same. In mysql it would look like this (I think):
SELECT table1.sampleid, table1.easting, table1.northing, table2.timestamp
FROM table1, table2
WHERE table1.timestamp == table2.timestamp
ORDER BY table2.timestamp ASC;
~ Eric.
David Finlayson
> eastings from a table of ship navigation gets written to a second
> table of sample locations only where the two tables have matching
> timestamps. So I basically have timestamps for my samples, but no
> positions. I'm unsure of the correct sql syntax (using Sqlite):
> Timestamp == Timestamp in Station_Samples." | db.execute
table2.timestamp FROM table1, table2
fyi I've got a few Matlab scripts for lining up and interpolating
positions from a GPS log & a recording instrument. Basic idea is the
recording instrument is taking a reading every 10 sec but the GPS only
every 30. I want a x,y column with my sensor data so figure out a
position for each record, then filter & calc a R:G:B column, then import
with v.in.ascii for snail-trail plotting & interpolation. It works
pretty well as the ship's movements are pretty steady vs a 2nd order
fit. Currently they are task specific but if I get the funds to do more
with that data I can revisit them & put together a more general script.
I can share the basic idea though if you are interested.
Hamish
I'm proud of a little script I wrote that can extract dates from
tabular data and convert them into alternative formats. I wrote it to
work a lot like sed, you pipe tabular data into the filter and it
converts the date into another format on stdout. Works great for time
series stuff.
I find it really useful to convert time stamps in conventional date
formats into something called a Julian day. This is a monotonically
increasing day number used by astronomers that starts at around -4700
B.C. and has been increasing ever since. It simplifies date math to
addition and subtraction. It has the advantage over day-of-year
schemes in that there is a UNIQUE number for each day, so you can
still figure out if the data were collected on a Monday in spring (for
example).
If you are interested, the program is called redate.py and can be found here:
http://david.p.finlayson.googlepages.com/gisscripts
Hamish
David Finlayson
Hamish,
Sure, by all means. I'm definitely interested. Although I have zero
experience with Matlab, I could probably mirror the functionality through
bash.
~ Eric.
-----Original Message-----
To: David Finlayson
Cc: Patton, Eric; GRASSLIST@baylor.edu
Sent: 5/5/2006 8:12 AM
Subject: Re: [GRASSLIST:1002] Re: Populating fields of one table based on
Hamish
David,
That script may come in handy, thanks for pointing it out. It's funny,
around here, Julian day/time is a much-abused term that is used to refer
only to the particular day of the year in a 365-day sequence. I've given up
trying to explain to people that the true Julian day is the number of days
since 4700 B.P because the misunderstanding has become so entrenched it's
easier just to accept that March 12th of every year is day 071... :wink:
~ Eric.
To: Hamish
Sent: 5/5/2006 12:51 PM
series stuff.
example).
here:
are
import
more
script.
Hamish
David Finlayson
Hamish:
import with v.in.ascii for snail-trail plotting & interpolation. It
works pretty well as the ship's movements are pretty steady vs a 2nd
order fit. Currently they are task specific but if I get the funds to
do more with that data I can revisit them & put together a more
general script. I can share the basic idea though if you are
interested.
Eric:
through bash.
The Free software program "Octave" works in a manner "not dissimilar" to
Matlab. You can run basic array algebra scripts without worry. None of
the fancy UI graphics stuff works, but that's not unexpected. ML code is
about 1/3rd UNIX and 1/3rd C so it's quite easy to pick up if you have
experience in one or both of those, and it's easier to read than both.
I'll see if I can find a clear example; will get back to you off-list
sometime later in the week.
Hamish
