dear grass list,
i have two points, they do not belong to a vector map, i have found that i
can obtain the distance (in UTM and LAT/LONG locations) with this (ugly)
trick
grass$ r.profile map=rmap profile=x1,y1,x2,y2 2> temp_file
grass$ distance=$(awk ‘/length/{print $4}’ < temp_file)
this method needs a query to a raster map, which is unnecessary, is
something like d.measure available in r.* commands?
Thanks in advance
Patricio Toledo
On 1/27/06, Patricio Antonio Toledo Peña <patricioantoniotoledo@gmail.com> wrote:
dear grass list,
trick
Thanks in advance
Patricio Toledo
Try d.geodesic.
d.geodesic - Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set. (from the grass 6 manual)
Odoardo Zecca
Try d.geodesic.d.geodesic - Displays a geodesic line, tracing the
in a longitude/latitude data set. (from the grass 6 manual)--Odoardo Zecca
d.geodesic does not work on UTM locations and the result is on screen, i need it
on a variable to make some calculations.
still trying
