This is a beginner's question...
If I have imported 13 layers of roads data (each layer represents a county), can I combine the layers so that there is only 1 layer in my map?
I would like to build polylines for 1 layer and then export that in shapefile format.
Steven Gordon
Hi Steven,
I think you can try with "v.patch"!! the last version support the join
of the tables.. but the tables must have the same columns I think!!!
otherway if you don't care of attributes simply "v.patch" without
joining tables and then "v.build.polylines" and then v.out.ogr...
hope this help
map?
shapefile format.
Steven Gordon
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini@unipg.it
ivan.marchesini@gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
The simplest way is to add the maps you want to combine to the layer tree
(list of map layers) in the GIS Manager and press the display button.
Michael
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Date: Wed, 1 Feb 2006 12:55:26 -0600
To: GRASSLIST <GRASSLIST@baylor.edu>
Subject: [GRASSLIST:10118] Combining layers
map?
shapefile format.
Steven Gordon
