[GRASSLIST:10225] RE: Three questions on ps.map
Sorry for 'bumping' my post, but these problems are important to me. Any
body having an Idea? 8The first one, I can fix with some manual editing
of the ps file, the others are worse..
Morten
From: owner-GRASSLIST@baylor.edu [mailto:owner-GRASSLIST@baylor.edu] On
Behalf Of Morten Sickel
Sent: Tuesday, February 07, 2006 9:01 PM
To: grasslist@baylor.edu
Subject: [GRASSLIST:10194] Three questions on ps.map
Hi
I am using ps.map and I have a few questions regarding it. My map is
build up with a number of vector layers
1) I am getting a frame around the map. Is that possible to avoid?
2) Is it possible to put the unit on the scale bar?
3) I have a vector layer with a closed polygon where I just want to draw
the outline. I tried using vlines, but then nothing showed up. This may
also be some problem with how the layer is defined.
Morten
Morten, i don't have answers for number one, but you could try to use the TEXT command with ps.map to force the units next to your scalebar. A hack, but it shoudl work.
You should be able to just draw outlines of vectors with vareas, just make your fcolor 'none'.
G'luck
-Ian
Morten
Hi
Morten
What happens if a big asteroid hits Earth? Judging from realistic simulations involving a sledge hammer and a common laboratory frog, we can assume it will be pretty bad.
  - Dave Barry
This message has been scanned by Postini anti-virus software.
