[GRASSLIST:10296] attribute select ??
just a little hint....
I have a series stored in a pg tabel SERIES with (KEY | DATE | VALUE) fields...
I have a vector with X,Y,Z,CAT
the relation between CAT and KEY is 1 to many....
so I cannot connect attribute with v.db.connect......
Is there a way to direct connect a selection to the vector?
I mean something like
v.db.connect table = SELECT KEY, VALUE FROM SERIES WHERE DATE="2006-01-15"
so to have a 1 to 1 relation between CAT and KEY !!!!
Otherwise I have to store X|Y|Z coordinates in the table and import the selection as a new vector.... :frowning:
Maxi
Eng. Massimiliano Cannata
Scuola Universitaria Professionale della Svizzera Italiana
Istituto Scienze della Terra
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 18
Fax +41 (0)58 666 62 09
