[GRASSLIST:1030] batch i.points?
I could download a lot of ortophotos with the same geometry (say 400x400 pixels) and known coordinates at corners.
However it seems i.points runs only interactive. There is a way to get this process automatized?
As you can see I'm pretty newbie on GRASS, but I could do some scripting work if there are some examples. Any pointer would be helpful
Thanks in advance
Roman Muñoz
tatel said:
Markus' script at
http://mpa.itc.it/grasstutor/scripts/create_locat.sh.txt
might help.
Moritz
