[GRASSLIST:10311] robinson (winkel) projection
I would like to convert a lat/lon map into a robinson (winkel) projection.
does anybody has experience with the creation of a robinson (winkel)
projektion in GRASS? It seems to be supported (robin, winkel,...) but I
haven't found out, how to create a robin location in GRASS and which
parameters a normaly used.
thanks
  Otto
Otto, I have made some robinson locations for my work, and the process is pretty straight forward. After selecting 'create new location' when first opening grass, select that you would like to use 'Other Projection' when asked for your coord. system. When asked to specify your projection name, just use 'robin'. Select your datum as usual. You will then have to input your central parallel, central meridian, and preferred units. For most robinson projections that you see in atlases, the central parallel is the equator (0), and the central meridian is the Greenwich meridian (also 0). I usually use meters as my preferred units.
Degrees would be really nice as a standard unit for these kinds of projections, but since their absolute length varies depending on your location on the earth, they can't be used in grass. My workaround to this has been to make a vector grid in a latlong location that is spaced about ten or fifteen degrees apart for the entire earth. I then project (with v.proj) that vector file into my robinson location as a first step so that I can see where I am in the world.
Once you are done with all of that, use r.proj and v.proj at your leisure in your new location.
Hope this helps,
Ian
On Feb 15, 2006, at 4:25 AM, Otto Dassau wrote:
thanks
  Otto
What happens if a big asteroid hits Earth? Judging from realistic simulations involving a sledge hammer and a common laboratory frog, we can assume it will be pretty bad.
  - Dave Barry
This message has been scanned by Postini anti-virus software.
One important thing I found - use a sphere, not an ellipsoid. If you use an ellipsoid, there will be an approx. 20000m N-S shift at around 45 deg N and S (for the Robinson, at least), which is quite noticable at any scale. I agonized over this for a while, using WGS84 ellipsoid out of habit, and even thought it was a bug, until I figured out the cause. -> use a sphere for global projections.
Hope this helps,
Ian
thanks
  Otto
William Kyngesburye <kyngchaos@kyngchaos.com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
William, I have not seen this with my Robinson locations. Are you sure about this? Could it be that your original dataset was using a sphere but you imported it into a wgs84 location. I had this trouble originally with Smith and Sandwell data. Seems like a major bug if your observation is true. Has anyone else ever seen this with Robinson projections?
-Ian
Hope this helps,
Ian
thanks
  Otto
  - Dave Barry
Ian,
you may want to enjoy the new d.grid which supports LatLong
grids in non-LatLong locations:
http://grass.itc.it/grass61/manuals/html61_user/d.grid.html
-g
    Draw geographic grid
GRASS bug #2558
I just noticed that my latest comments to help close that bug didn't make it into the tracker. I'll have to dig those up and resubmit them.
I've been working with the GLOBE DEM, which should be in WGS84, and is in a WGS84 latlong location. I first noticed the problem when upgrading PROJ from 4.4.7 to 4.4.8. I think something was fixed in proj, and so broke a glitch I was depending on (unknowingly) in the GRASS-PROJ interaction.
If the latlong DEM was really sphere-based but in a WGS84 location, other projections should also be having problems. I haven't seen any other projections with this shifting issue.
-Ian
Hope this helps,
Ian
thanks
  Otto
- Dave Barry
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
thanks a lot for your help. I was finally able to create a (hopefully correct)
robinson projection in GRASS and to convert the originally lat/lon, wgs84 map
projection into robinson with wgs84 ellipsoid.
-PROJ_INFO-------------------------------------------------
datum : wgs84
towgs84 : 0.000,0.000,0.000
proj : robin
ellps : wgs84
a : 6378137.0000000000
es : 0.0066943800
f : 298.2572235630
lat_0 : 0.0000000000
lon_0 : 0.0000000000
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1.0
Am Mittwoch, 15. Februar 2006 21:32 schrieb William Kyngesburye:
GRASS bug #2558
I used a fresh PROJ.4 cvs snapshot and it worked fine.
> -Ian
I tried both (sphere and wgs84) and compaired with vector maps reprojected
from other projections (utm and latlon) to find out about possible shifting
problems but it seems to be ok so far ... but I will have to do further
tests.
  thanks a lot
    Otto
>>> preferred units.
>>> I am in the world.
>>> Hope this helps,
>>> Ian
>>>> Hi,
>>>> projection.
>>>> (winkel)
>>>> winkel,...) but I
>>>> which
>>>> thanks
>>>> Otto
>> depressed robot?
> - Dave Barry
already happened.
GDF Hannover - Solutions for spatial data analysis and remote sensing
Office Hannover - Mengendamm 16d - D - 30177 Hannover
Internet: www.gdf-hannover.de, Email: info@gdf-hannover.de
Phone : ++49.(0)511.39088507, Fax: ++49.(0)511.39088508
