Here is the new package:
http://mpa.itc.it/radim/wingrass/qgis-0.8.0-preview-win32-060508.zip
The problem with NAD grid files did not exist in fact, I just
tested with a file which was outside available grid files.
There is however little problem with grid files, if GRASS plugin
is loaded PROJ will search in qgis/grass/etc/nad even if
qgis/shar/proj is available, the directories are currently identical
so it cannot cause any problems for users.
Radim
